Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Everett-Morrison Motorcars -- Speak with Julie and Brett
December 2025
Old 06-25-2010, 05:03 PM
Jerry Clayton's Avatar
Default tires and wheels
Well as I am going to be allowed to work on my car after I finish my wifes 34 coupe---Today I bought a set of tires and wheels plus steering column and guages. Tires and wheels are 18 front and 12 x 19 rears to allow some bigger brakes----------
Old 06-25-2010, 06:09 PM
Jerry,
Who's LS block are you using? Also, not sure that E'brock and Dominator will clear the EM hood. (?)
Chas.
Old 06-25-2010, 06:31 PM
Right now the car has a WS6 pontiac/t56 in it but I'm rounding up parts for a drysumped 427---just right now I don't know if i'm going to do long strke/small bore or shorter stroke/large bore---the short stroke large bore is what I'm leaning toward for better valve flow numbers---also with the shorter stroke I can use more agressive acceleration than the long strke and run into the 8500-9500 rpm for top end stuff.
Also--My hood has the bigger scoop to get more air
thanks for asking
Jerry
Old 06-25-2010, 06:48 PM
8500+ in a Cobra would be a step on the wild side.
GM LS-X iron or Warhawk aluminum block? Not decided yet?
Chas.
Old 06-25-2010, 11:35 PM
It'll be a GM alum block--don't know yet if I'll get a LS 7 or do the Darton sleeve thingie in one of the LS laying around here
The GM LSx iron thing is very heavy as are the warhawks
Probably in the end sceme of things Callie crank will have the Honda bearing size---
Old 03-05-2012, 06:29 PM
Need advice on brakes; our Wilwoods have been inadequate since day 1.
Old 03-05-2012, 08:21 PM
^^Need more specifics on your combination and usage to help you.
Chas.
Old 03-05-2012, 08:56 PM
Default brakes
dynalite big brake kit front 12.19 diam.with the dyna pro 6 piston calipers, and I use a 7/16 tilton balence bar set up, with 7/8 front cylinder, and 1 inch rear, works very well, oh ya rear brakes are 11inch roters 4 piston calipers.
