Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Everett-Morrison Motorcars -- Speak with Julie and Brett
December 2025
Old 10-09-2022, 04:25 PM
mjhcobra's Avatar
Cobra Make, Engine: Everett Morrison, 428
Hi Tom,
How do I "pull" the pull cord when the door panel is installed over it? Did you cut a slit in the back piece of vinyl for access? I tried cutting a hole in each end of the back vinyl and threading the pull cord thru it, but I could not get the screw in the door at end of the cord by the hinge.
Thanks for your time,
Marty
Old 10-10-2022, 08:54 AM
Tom Wells's Avatar
Marty,
Yes there is a slit. The two photos show the panel and an attempt to show the slit.
It's the passenger door, and forward is to the left. The cord is about level with the stitching just below the top of the pocket.
Hope these help.
Tom
Old 10-10-2022, 12:25 PM
mjhcobra's Avatar
Tom,
The pics help a bunch. I assume that having a vertical slit at both ends allows for access for installing the screw near the door hinges that holds that end of the cable.
To bad EM didn't use the normal door hardware. Having the cord reminds me of my Dad's 59 MGA, which had the cord also.
Marty
