Old 11-27-2009, 03:37 PM
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
Question turkey pans
who sells the turkey pans? what carbs can you fit in them any problems with aftermarket return spring brackets, and dual feed lines? i am just looking for information and ideas
Old 11-27-2009, 10:27 PM
Gunner's Avatar
Finish Line, Cobra Restorers, others. Most will fit standard carbs with dual feed lines no problem. You sometimes have to enlarge and shape the pan holes to accomodate a specific setup. For all but the biggest changes, a Dremel with a stack of sanding drums and a little patience and care will get you where you need to go.
Old 11-28-2009, 02:58 AM
when you run a turkey pan i assume there is a gasket then the pan then another gasket then carb? i already have the cobra oval air cleaner assbly with the larger k&n filter so i am unsure wich one to run. thanks for the info.
Old 11-28-2009, 06:39 AM
Stentor's Avatar
Default Kirkham
I believe Kirkham sells a couple different versions of a turkey pan.
Old 11-28-2009, 08:03 AM
A-Snake's Avatar
Original Shelby Owner
Cobra Make, Engine: CSX2321
Turkey Pan
Old 11-28-2009, 08:43 AM
SMOKNAC's Avatar
Cobra Make, Engine: SPF / FE428
Default Turkey pan
I got mine off E-bay, they sell Polished or clear anodized.
Idem # 260482298241.
I bought the anodize one, Looks awsome.
Old 11-28-2009, 09:02 AM
mickmate's Avatar
I got all tooled up to make them and have laser cut bases and forming tools ready etc but just can't compete with those e-bay guys on price and quality. I can provide or install the bases on to theirs to make your TP a convertible if that's the way you want to go for carb adjustments etc. Yes they just need a double gasket and bolt right on.
A Snake that's funny but makes me a little ill looking at it this time of year!
mickmate
http://www.actoncustom.com/
Old 11-28-2009, 10:30 AM
MFE III's Avatar
Cobra Make, Engine: Hurricane Motorsports, 427w
Mine was made by a guy I came across here, Lonny. I'm running a small block, so he had custom make it to fit around my distributor. He did a great job. If interested, PM me for his email address.
Hurricane Motorsports #1053; 427w
Old 11-28-2009, 10:58 AM
Gunner's Avatar
Yes, you put a gasket under the pan and under the carb.
I got my car with a turkey pan and small air cleaner. Because I have to fit it with a PCV and closed breather to pass the California exam, and because I wanted better breathing for daily driving, I fit it with a long oval that has room on the underside to attach the breather hose. Both look good and fit well. I will be putting the pan and S&H cleaner back on for show, but the long oval has twice the breathing area of the little cleaner. Some folks have done calculations and shown that a K&N filter in the small air cleaner should provide enough flow, but a K&N in the long oval leaves no question about it.
It's your choice. Both look good and even the long oval is reasonably correct.
Old 11-29-2009, 05:26 AM
Cobra Make, Engine: Unique
Default Kirkham
I think Kirkham was making one that was two piece that solved some of the PITA they are to deal with.
Old 11-29-2009, 05:59 AM
double ugly's Avatar
I bought one from Finishline because the price was right. I got what I paid for as the quality was very poor. Dents etc. They let me return it though. I ended up with a very nice $$$ pan from Kirkham but, again, I got what I paid for.
double ugly
