Old 12-18-2009, 11:27 AM
Default 428CJ Cooling
Hello All,
After a long wait to pull the trigger, BDR789 is arriving in late January and I have decided to go with a 428CJ / TKO 600 combo. I have heard the 428's run a little hotter than the 390's, so my question is regarding ancillary equipment.
1) Do I need to run and oil cooler?
2) Is it wise to install 2 pusher fans?
I would rather do the work at the beginning that add it on later.
Thanks!!
Old 12-18-2009, 11:49 AM
Tony Ripepi's Avatar
Cobra Make, Engine: TBD
HI BDR,
I don't know whether the 428 runs hotter than a 390/427 but, they are all FE engines and I would recommend both the oil cooler and a set of high CFM puller fans. The puller should be on a temp sensor in the radiator to kick them on when the temp reaches a preset temp. You may also want to install a cockpit switch that will allow you to kick the fans on manually. The preset temp for the puller shoild be above the temperature that the themostat opens, this will make sure that the engine warms, allows cold fluid to flow out of the radiator and kicks on to keep the radiator fluid at an even operating level.
The pusher fans tend to be more decoration that functional components,and can actually interfere with the flow of cooling air into the Radiator.
Tony R.
Old 12-18-2009, 11:57 AM
dcdoug's Avatar
I find my pusher fans actually make a real difference. Depending on where you live, oil coolers can be a pain if you drive your car in the winter and its cold out (less than 40 degrees). At any sort of speed, the oil doesn't really get hot enough. I have mine blocked off with lexan right now, but that still doesn't quite do it. They make thermostats to cut off the oil cooler loop, which you might consider. I'd probably still go with an oil cooler though.
www.partskeeper.com
Old 12-18-2009, 12:08 PM
Gunner's Avatar
Cobra Make, Engine: ERA 707, 446ci FE
If the radiator and primary fan are adequate and the engine is not extreme, you can probably dispense with the pusher fans. You might at least hold off on buying and installing them until you have the car built and sorted out. (Make sure the wiring harness for them is in place during build; that will save a ton of effort later.)
If you follow all the rules about the radiator, thermostat (don't forget to drill bleed holes) etc. you will likely not have any cooling problems. And, of course, be sure the block is thoroughly boiled and cleaned before assembly... a deep blockage in the water jacket can cause lifetime problems.
The oil cooler is de rigueur for originality, but it can be a complete PITA any time you drive in cooler temps or for short drives. Mine has the remote oil filter and cooler, and I have yet to get the oil past 70* even on warmish days and long freeway drives. So my next project is to cut in a Canton oil thermostat - pics and details will be up when I'm finished. That will keep the cooler and at least one quart of oil out of the loop while it warms up and stays at 80* or higher, which is where the oil temp needs to reside for proper lubrication and boiling out water and other volatiles that don't belong there. I would have removed the cooler entirely if it didn't routinely exceed 100* here through the summer; I suspect I will need the cooling capacity for longer summer drives.
= Si Opus Quadratum vis, angulos praecidere noli. =
Old 12-18-2009, 01:38 PM
Blittleton's Avatar
CC Member / Sponsor
I have done several FE's in Backdraft's. I haven't seen any real problems. I would upgrade to the larger radiator and I would install a oil cooler with a thermostat. If you don't have one you are just pissing in the wind anyways. I have one in Midland TX and no issues so far.
Bill
Squeaky wheel always gets the grease!!
www.gcperf.com
Old 12-18-2009, 03:39 PM
Woodz428's Avatar
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
I have decades of experience with virtually all FE size engines, in the same confines there shouldn't be any signicant temp difference. I can see how some of the 390 blocks that have been bored to a 428 bore might run a little hotter, but a factory block? I don't think it should.
You also have to keep in mind that HP=heat, so the more power that you want to get will create more heat to be dispersed.
WDZ
Old 12-18-2009, 03:45 PM
Woodz428's Avatar
You might want to check out the bypass device that one of the board members used to offer. It allows you to divert various percentages of oil through the cooler. It allows full flow and (I believe) none, by the turn of a knob. Pretty slick and machined from solid billet. I am sure someone will know his name. I feel bad since I used to know him from SCOF,but I haven't been there for a while. I do know he helps with the London Cobra show and works in a machine shop ( may even own it), and makes some nice jack stands that can be packed flat...also billet.
WDZ
Old 12-18-2009, 07:38 PM
Gunner's Avatar
Thanks, I've been referred to it every time I make a post about the oil thermostat.
It's a pretty piece, but it's over twice the cost of the equally pretty Canton billet thermostat... and that for manual control when the Canton is completely automatic. I see no advantage to it at all, to be honest.
10/10 for execution, but 5/10 for practicality. Maybe it's more useful to the track guys who both fiddle with every setting possible all the time and love to do so.
Old 12-19-2009, 03:13 PM
Cobra Make, Engine: Backdraft 879, Indigo Blue / Wimbledon White, 428 Cobrajet, TKO 500
Default Thanks Dudes
Thanks for the info, guys. I will most likely sort her out first and play it by ear to see what happens....just wanted to be sure that I was on the right track.
If you noticed, I came down with dyslexia yesterday and had my BDR# wrong, so my handle is now correct . I'll give you updates the progress and seek your wise counsel as things arise
Old 12-19-2009, 05:20 PM
Woodz428's Avatar
Did you notice it or did you get a call saying "Hey...That's MY car"?
WDZ
Old 12-18-2009, 03:49 PM
dcdoug's Avatar
If you do some searches on oil cooler thermostats I'm sure it will come up. There have been some posts with pretty slick set-ups.
www.partskeeper.com
Old 12-22-2009, 03:59 AM
Danr55's Avatar
BDR, I run a 428 and I live in Arizona where the oil will get hot if you don't have an oil cooler. I run a 4 core aluminum radiator, an oil cooler and a black magic puller fan. Engine temp runs right at 210 in the summer and 190 in the winter. Oil temp is within about 5 degrees of the water temp.
Dan in Arizona
CCX3209
Rate This Thread:
