Old 03-14-2010, 08:09 AM
Cobra Make, Engine: B&B
Default FE Timing
Guys I need your suggestions on possible timing problems with my FE. It's a Unilite dist. with a Mallory Hyfire. Vac. line is installed. Idle speeds run fine, up to about 3000, 3200 rpms. Timing is set at 35* total at 3000 rpms. Above 3000 engine starts to brakeup. The engine even at low rpms doesn't have a lot of crispness to it. It seems to run hard. Warm starts are hard starts on the starter. Are there any adjustments you can suggest.
