Old 05-14-2010, 04:48 PM
Default will water cool as well as antifreeze?
will antifreeze keep the motor as cool as antifreeze?
Jon
Old 05-14-2010, 04:56 PM
PatBuckley's Avatar
Straight water will cool better than anti-freeze.
Old 05-14-2010, 04:59 PM
x2 on pure distilled water ... most racing organizations will not allow antifreeze . It makes things real exciting if you hit a patch of it on the track . Try running distilled water and water wetter with the water pump lube in it .
Makes it a lot easier to clean up if you have to change a hose of spring a leak .
CobraEd's Avatar
Except it has no rust preventative and water pump lubricant additives as found in antifreeze.
________
________
Old 05-14-2010, 05:13 PM
gsharapa's Avatar
Actually a 50/50 mix of distrilled water and antifreeze with some water wetter will cool much better than straight water or distilled water...
CAV GT40
Old 05-14-2010, 05:15 PM
CoupedUp's Avatar
Cobra Make, Engine: SPF Brock Coupe #88, Keith Craft 427w
That's what Water Wetter is for. I run distilled water with Water Wetter.
Doug
Now back to my midlife crisis...
Old 05-14-2010, 05:17 PM
Jamo's Avatar
Super Moderator
Assolutely...H2O/WW
Jamo
Old 05-14-2010, 06:19 PM
bobcowan's Avatar
Not exactly true. Pure water carries and transfers heat energy better than a 50/50 mix. But the mix has a higher boiling point under pressure, and a lower freezing point.
http://www.redlineoil.com/content/fi...ech%20Info.pdf
Old 05-14-2010, 06:25 PM
undy's Avatar
The heat rejection factor of water being 1.0 pure antifreeze has a .8 heat rejection factor . Any addition of antifreeze to water porportionately reduces the mix's heat rejection capabilities. Pump lubrication, rust inhibitors, elevated boiling points and lowered freezing points are the only advantages of a glycol/water mix.
Too many toys?? never!
Old 05-14-2010, 08:40 PM
Well hopefully the freezing weather is over here in Oregon for the time being. It better be, I just dumped the antifreeze solution I've been running through the winter and changed out to water and wetter for the summer.
I can actually SEE the difference in temperatures running water vs antifreeze mix. Water alone is better.
Old 05-14-2010, 08:45 PM
Bob In Ct's Avatar
The only advantages? If you can you should run 50/50 all year long.
Old 05-14-2010, 09:19 PM
bobcowan's Avatar
Why?
I run about a 25% AF + a surfactent year round. Seems to do OK. In cooler temps I have to put duct tape on the radiater to get the temps up to 180*.
Old 05-15-2010, 06:09 AM
The only time I use anti-freeze is if the car will be exposed to freezing temps. Since my car is never exposed to freezing temps; maximum cooling, pump lube, and corrosion protection are achieved with water and Prestone Super Anti-Rust. There are other corrosion inhibitors that will do the same thing as Prestone. I won't comment on WW and other surfactants except to say that if it makes you feel good knowing it's in there, then pour a bottle in... the odds are that your water pump seal will be just fine...
Scott
Old 05-15-2010, 06:25 AM
Ron61's Avatar
Post
Same here. Never put any anti freeze in. Just distilled water and a bottle of water wetter. And it gets near the Arizona temperatures around here in the summer. Like 118° with a heat factor of 124/128.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 05-15-2010, 06:42 AM
Dwight's Avatar
Smile
I live in North Alabama. Our weather ranges from mid 20's to 100 degrees. I drive year round with 25% AF and 75% distilled water. I don't when it gets below 45.
I have my fan set to come on at 205 degrees. I run fuel injected so my operating temp is 195.
over 27,000 miles
my big block buddies run 25/75 and water wetter.
Dwight
Old 05-21-2010, 01:58 AM
PANAVIA's Avatar
Agreed , distilled or highly filtered water with some AF and WW.
75% water,22% AF, 3% ww.
Feel blessed in oregon for the good water, Tap water in California --isn't .
Plus modern green antifreeze is scary ! It just doesn't taste the same as in the 1980's.
Steve
Old 05-22-2010, 11:10 PM
Bxx1's Avatar
My car runs much cooler with less than without AF. I had to dump my AF for track day and since that time the Cobra has never come close to over heating. My only concern is engine block corrosion etc. I use WW and am investigating quality anti-corrosion additives. Any feedback on quallity corrosion inhibiters is appreciated.
Old 05-23-2010, 02:10 PM
if your car is exposed to freezing temps. and you dont want to drain your rad. every year then run a mix that will keep your coolant from turning to ice.....and yes it will crack your block....if your not around freezing temps. then run distilled water and water wetter and a good corosion inhibitor like super anti-rust....
80% water 15% ww and 5% anti rust that should keep your cooling system operating at its best along with a coolant recovery tank.
