January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 09-30-2010, 02:03 PM
Default PCV Valve orientation, does it......
.....matter if it is horzontal or vertical?
I have a threaded PCV valve and instead of drilling and tapping the crank case cover plate to mate, why can't I screw the PCV valve into the port under the rear carb (blue thunder 2x4) and run the hose from there to the crank case cover plate, which already has a nipple on it.
Does it matter if the PCV valve is vertical or Horizontal?
Rate This Thread:
