Old 10-01-2010, 04:38 PM
Cobra Make, Engine: ERA #539/427 Holman Moody #7HM20 from 1967
Default Screw threads size in timing cover holding 1965 427 FE timing pointer
My engine came without the timing pointer. I bought a new pointer from Dearborn Classics but cannot make out the internal threads of my timing chain cover. Hard to see under there if stripped or if I just need the right screws.
I think they may be 10-24 or they may be self tapping.
Old 10-02-2010, 06:33 AM
I don't know which cover you have. My Shelby aluminum cover is drilled/tapped for 10-24.
Rodger
Old 10-03-2010, 01:11 AM
Roger thanks for picking up on this question. I have the stock Ford FE timing cover. I tried a 10-24 machine screw but it only went in about 3/4 turn. If i knew the correct thread I would start with confidence to blind tap it. Access to the front is difficult as I am not on a lift. I just do not want to mess up any good threads I have or have left.
Old 10-10-2010, 12:14 PM
Cobra Make, Engine: ERA - 427
I measured these years ago and *remember* them to be 10-28 UNS
(unified screw thread)
Old 10-12-2010, 05:06 AM
And the factory fasteners are self tapping - or more correctly self stripping.....
Survival Motorsports
"I can do that....."
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
Old 10-13-2010, 09:51 PM
The original screws for a cover with 2 were a part number 373913-s list as Screw No. 10-24 x 5/16"
Look under the 6019 parts listing at the bottom of the page.
http://www.gessford.com/images/fe427-01parts.gif
Old 10-13-2010, 11:39 PM
PANAVIA's Avatar
Barry_R +1.
The little guys were self tapping (ish) they can be had from AMK if you are indeed in need of correct hardware.
Old 10-14-2010, 01:57 PM
Danke gentlemen, now with the screws, spark plug piston stop, degree wheel, and my new MSD timing light I can check my distributor set up!
Sometimes it is the simple things in life
