Old 10-06-2010, 11:53 AM
Originally Posted by elmariachi View Post
I just bought three caulk-sized tubes of the Mystik. PM me if you want one.
I actually use the Dow stuff. It's probably all about the same. Guys that are running open gears out in the field are not going to put up with a grease that comes off in the rain.
Uh-I didn't think so...
No... but I'll give you a hint. It's something you've always wanted. Yes, you're going to say it's a waste of money, but you're also going to say that it's really cool and you'd be tickled pink to find it under your tree come Christmas.
Old 10-06-2010, 11:59 AM
Originally Posted by era chas View Post
an in-dash, quick-disconnect, zagat guide holder?
lmao.
Old 10-06-2010, 12:04 PM
lmao.
Well I can assure you I'm not eating axle grease.
Old 10-06-2010, 12:11 PM
...you'd be tickled pink to find it under your tree come Christmas.
Scarlett Johansson ???
Chas.
Old 10-06-2010, 02:07 PM
Uh, sorry... no. But something almost just as nice. Here, I'll give you a visual clue:
Old 10-06-2010, 02:14 PM
I don't know what you bought from PMS, but I'd be careful consuming the contents of that bottle. I've had it and its hot.
Old 10-06-2010, 02:23 PM
dcdoug's Avatar
You got a hibachi that hangs off the side of the cobra? That's unique.
www.partskeeper.com
Old 10-06-2010, 02:27 PM
No you fool-this is a v/c gasket thread. He puts that between the head and the v/c gasket...PAY ATTENTION!
Chas.
Old 10-06-2010, 02:28 PM
I'll bet he bought their "spectroinclinomediamometer", which he uses to measure the color refraction off of the Canton oil pan bolt heads.
Come on Pat, fess up, did you rob the kids' college fund and get a Bridgeport lathe?
Old 10-06-2010, 02:30 PM
Its been a long day, I wore myself out earlier building that FIA car in my head (inside joke.)
You put that Habanero sauce anywhere near an FE and you're guaranteed another 30 HP.
Old 10-06-2010, 02:42 PM
RodKnock's Avatar
I'm curious. Why does Patrick always include "gratuitous" pics of his hands?
Does he think he's a hand model like George from Seinfeld?
Old 10-06-2010, 02:45 PM
Any guy that has to use his hand that much...
Chas.
  #33 (permalink)
Old 10-13-2010, 10:45 PM
PANAVIA's Avatar
pentroofs leak. you can try some of those spreaders we used to see on 327's
the other thing is to use the double THICK gasket -- or a pair of gaskets per side to absorb the ramps between the intake and the head in the front and rear of the FE cylinder head.
Rodney -- "gratuitous">?
wasnt like he posted pics of Melinda Windsor!
  #34 (permalink)
Old 10-14-2010, 07:00 AM
Snakebit's Avatar
Mikes Hot Sauce "I put that **** on everything!" All kidding aside, try Permatex Hylomar. Real stickey stuff, but the gaskets can be removed and re applied. I have used this stuff on intake manifolds and valve cover gaskets and no leaks!
Snakebit
  #35 (permalink)
Old 10-14-2010, 11:51 AM
So DC-what's the answer??
Did you fill the head/intake joint or are you waiting to hear more magic solutions?-and forget trying the double gasket remedy. If one gasket won't conform to the step, neither will two-even at double the torque. A few guys have given you worthwhile help-now what do you tell us???
Chas.
  #36 (permalink)
Old 10-14-2010, 01:28 PM
dcdoug's Avatar
I am going with your suggestion of R/S with cling wrap to prep the rail joint. Then with either the Felpro blue stripe or Felpro rubber (I will probably give the blue stripe another crack). R/S to glue the gasket to the cover and then hot sauce for the gasket to head seal.
Actually, Elmariachi Jim is sending me a tube of brown OG grease and then I will use that for the gasket-head seal.
I didn't do either the rail joint prep or use the right grease last time, so hopefully that solves the issue.
Maybe Patrickt will let me try his new tool since I will check my lash at the same time.
www.partskeeper.com
  #37 (permalink)
Old 10-14-2010, 01:38 PM
A. There will be a $250 user fee.
B. You have to get a manicure and wear at least a Patek Philippe in the 'hand' picture.
Now-you sure you wanna do that?? Or adjust valves with feelers like Brent, Barry, Keith, Clayton, George, Tom, LeFevers, Marichi, me...
Chas.
  #38 (permalink)
Old 10-14-2010, 01:45 PM
dcdoug's Avatar
I used feelers last time and think I did a good job (actually outstanding, but I was slow). But the tool does look kind of cool and might save me some time having to re-adjust when the lash changes as you lock down the nut. I got better at compensating for that, but still took me a long time to get all of them so they felt like they had exactly the same resistance on the feeler.
www.partskeeper.com
  #39 (permalink)
Old 10-14-2010, 02:13 PM
You can over-worry this stuff. Use the feelers and the more you do it the more natural and faster it gets. Plus you will improve the accuracy by feel. Every-day engine builders do this in under 10 minutes. And they are accurate.
In case you're doing each cylinder 90 deg around the firing order, there's a much faster way. If you know this already, I apologize-just trying to help ya.
Set #1 cylinder to TDC compression and adjust the following valves:
#1-I & E. #3-I. #4-E. #5-E. #7-I. #8 I & E.
Set #6 cylinder to TDC compression and adjust the following valves:
#2-I & E. #3-E. #4-I. #5-I. #6-I & E. #7-E.
I just saved ya $250 so put that towards a Patek for your Ms
Chas.
  #40 (permalink)
Old 10-14-2010, 03:21 PM
dcdoug's Avatar
I do know about this method, but was doing it the long way to be sure that I did it right as it's pretty hard to screw it up the slow way.
What can I say, I'm still a rook.
www.partskeeper.com
