February 2026
11-20-2010, 05:59 PM
AL Flywheels ?
Which is better?
Fidanza 186541 for $390
14lbs.
Mcleod 563210 for $576
18lbs.
Why is Mcleod so expensive? What is the difference?
Thanks.
11-20-2010, 06:39 PM
Cobra Make, Engine: superformance/427 fe ford
does the fidanza have a steel insert? i take it does. maybe thickness make a difference or material or maybe if it's made out of USA, might be cheaper. hate to say that but thats just what this country has come to. but thats a different story.
1952 MG TD - 53 HP 1970 SS454 Chevelle - 900hp 2007 spo2669 - 485hp 2001 Spclconst. softtail - 114HP 2006 Roadglide - 88HP
sold Roadglide.....bought 09 XR 1200 - 90 hp stock
i would rather live one day as a lion, than one thousand days as a lamb.
11-20-2010, 06:41 PM
KY
If you're going for aluminum, my thought is that you're going for lightweight....so you should go for the lightest piece. I sell Fidanza, RAM, and McLeod flywheels, and the Fidanza is a very nice wheel.
Both flywheels that you mentioned have multiple pressure plate patterns on them, so they will work with any clutch application.
I can beat both prices that you mentioned. I use the Fidanza quite a bit, even on my own FE stuff.
With the McLeod, you're paying for their name. I have almost stopped selling McLeod stuff because of the pricing.
(And yes, both have steel inserts. You have to have a steel friction surface, or the disc would wear right through the aluminum.)
11-20-2010, 06:50 PM
hey brent, what do you know about low ground clearance flywheels and bellhousings and clutches. building bonneville car and looking for a 104 tooth flywheel setup. have 608 cu in drysump motor to install on.
11-20-2010, 06:51 PM
KY
Let me know what you're working on....BBF? How much power?
11-20-2010, 06:53 PM
1000hp@7200 rpm have a liberty pro-shifted m-22 for trans in a 72 camaro
11-20-2010, 06:54 PM
KY
Transmission?
11-20-2010, 06:56 PM
also would like to run hyd. thro out
11-20-2010, 06:59 PM
KY
Is it a Ford application? What transmission?
Originally Posted by blykins
Transmission?
check response number 6.
11-20-2010, 07:01 PM
11/8 x 26 spline input. M-22 muncie stuff
KY
Ok cool....
11-20-2010, 07:05 PM
KY
Looks like Tilton has everything that you need. I'd go with one of their 104T flywheels that's setup for one of their 7.25" twin disc button clutch kits. They have aluminum/magnesium bellhousings for Chevy applications as well.
Want pricing?
11-20-2010, 07:07 PM
i know it's late back east, and it's saturday nite. so if you want to get back to me later, thats ok. just know that i am in the market for such a clutch setup and any help would be much appreciated
11-20-2010, 07:09 PM
oh ............well hell yes. thanks
11-20-2010, 07:25 PM
KY
Tilton has a complete Ultimate Ground Clearance package consisting of:
*8 lb magnesium bellhousing
*3-disc 5.5" clutch, 1-5/32x26 (will work with your 1-1/8x26)
*102T flexplate (approximately 8-5/8" diameter)
*Reverse mount Super Starter
*Hydraulic throw out bearing kit
It's $2999 for everything. Free shipping.
11-20-2010, 07:28 PM
brent, you have a pm
11-21-2010, 03:30 AM
KS
Cobra Make, Engine: jbl
Originally Posted by garry viohl
Which is better?
14lbs.
18lbs.
Thanks.
where are they manufactured?
11-21-2010, 04:47 AM
OH
Cobra Make, Engine: Everett-Morrison 427SC 302 smallblock. 431 stroker in the works, tremec 3550
Fidanza flywheels are manufactured in Perry Ohio, the next town over from me. Been there, bought the wheel. Nice folks. They also make the flywheels for Zoom, from what I understand.
11-21-2010, 05:27 AM
KY
With the Club Cobra discount, the Fidanza 186541 would be $359 + shipping.
