Old 03-02-2011, 07:10 AM
priobe's Avatar
Default FE broke deflector plate in valve cover
Hey All,
I was wondering if anyone ran into this problem. I have 427 FE running the Cobra 427 valve covers. I started up the motor last night and noticed a noise. After pulling the valve cover for inspection I found the deflector plate inside the valve cover was slightky dented and started coming loose.
I am running the erson rockers and with a cam shaft 245 / 250 lift 680 @50
[img][img]
Old 03-02-2011, 04:47 PM
Cobra Make, Engine: 2007 BDR FR Boss 302
appears to be either a loose rocker arm or shaft if its just making noise and hitting now. If its a new motor, poss too much lift for the covers and you'll need to put a spacer between the valve cover and head. This is the only reason for this issue that I can think of.
Old 03-02-2011, 05:53 PM
Cobra Make, Engine: Contemporary CCX33344 with original bore 427 SO.
Default Same Problem
I had the same problem at last years Dream Cruise, except mine came completely detached. Thought the motor was gone so I had it flatbedded home.
The nails holding it in had fallen out (luckily they stayed in the head). I replaced the nails and loctited them in. No problems anymore.
Old 03-02-2011, 06:24 PM
priobe's Avatar
I noticed that the nut for adjustment is what is hitting. I did however adjusted the valves recently and the gasket is smashed thin. If I had thicker gaskets as when they were new it would not hit. Some have said to remove the baffle, I decided to do this and see what happens. If anything I will make a better baffle and reattach.
Apparently, this is some what common with the erson rockers.
I wonder if others have had this problem
