  #21 (permalink)
Old 03-21-2011, 06:08 PM
Jac Mac's Avatar
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
We are only trying to save you the embarassment of the decimal point shifting several slots to the right in your $0.99 investment should the old bits of stem seal or circlips whatever, or the extra load of the HV pump if fitted decide to commit mayhem at a less opportune time in the future-- oil pump drive's , dizzy gear pins, rear main leaks etc are regular thread subjects around here..
Jac Mac
  #22 (permalink)
Old 03-22-2011, 03:13 AM
Default I hope you didn't give them the core
Steve V Steve I hope you didn't give the core to Napa. Guys are looking for the correct number parts for restorations. They might not care if there is a little play in the shaft. Some of these guys are the best machinist in the world and can fix any thing. If play is in the shaft, replace the shaft, new bushing in the housing, in bearing in the upper housing instaed of a bushing. I think you get the point. Get the Ford numbers and sell it on the FE forum or e-bay. As long as the housing is not damaged it can be rebuilt, Go get it back iof it looks orginial. Rick.
  #23 (permalink)
Old 03-23-2011, 01:54 PM
SteveV's Avatar
Cobra Make, Engine: 1964 T-Bird
Rick, I never thought about that. I'll look at it closer tonight, it's still setting on the work bench.
Thanks,
Steve
  #24 (permalink)
Old 03-24-2011, 09:05 AM
Z-linkCobra's Avatar
Cobra Make, Engine: Everett Morrison, All aluminum small block ford.
Originally Posted by Jerry Clayton View Post
Define forever
does that mean trouble free from now on or
Does that mean the engine will keep running after the oil pump drive shears off which will finish the engine off forever?
Now thats funny....lmao
" If it wont break em loose in 3rd gear, it aint enough power "
Rate This Thread:
