Old 08-26-2011, 10:03 AM
flaflier's Avatar
Cobra Make, Engine: ERA154 427 HR
Default Valve Cover Interference
I am in the process of switching from the lemans cast aluminum valve covers to the chrome pentroof covers. The problem I ran into was interference at the ends of the rockers hitting the ends of the VC. I was able to push the VC on, but not what I like. Has anyone else had this issue? Not sure I want to get spacers. Maybe double VC gaskets? Maybe a ball peen hammer selectively administered? Any help or direction is appreciated.
Thanks, Jim
Edit: The rocker STANDS are hitting the VC, not the rockers..
Old 08-26-2011, 10:36 AM
Rick Parker's Avatar
Are aftermarket rocker stands hitting or the ends of the rocker shafts?
Rick
Old 08-26-2011, 11:22 AM
flaflier's Avatar
The end rocker stands are hitting the VC, not the shaft.
Old 08-26-2011, 11:47 AM
FWB's Avatar
FWB FWB is offline
not unusual, i have a set of older PSE end stands that hit, i had to machine a angle on the side to clear the valve covers.
who's end stands are they?
fred
Fred B
Old 08-26-2011, 11:50 AM
FWB's Avatar
FWB FWB is offline
here's a pic to see what i mean.....
Fred B
Old 08-26-2011, 12:38 PM
Very nice setup. Great improvement over OEM. I will defer to FE folks with more first hand knowledge but my first thought would be to ask if a small amount of material could be removed from the end stands without compromising their integrity? Short of that modifying the cover would seem to be the only other option.
Rick
Old 08-26-2011, 12:44 PM
FWB's Avatar
FWB FWB is offline
thanks rick, i made the shaft stands and reverse engineered the PSE end stands.
end stands take custom head studs.....
Fred B
Old 08-26-2011, 06:11 PM
flaflier's Avatar
I believe they are Dove, without opening up the VC tonight. Here is an older picture I took.
It looks like I can take a little material off both end.
Old 08-26-2011, 07:05 PM
FWB's Avatar
FWB FWB is offline
you could probably get away with a little material removal just at the top outer edge, its probably hitting on the curvature of the cover.
i would grind the pointed end at the top too a tad....
yep
looks like Dove......are they his rockers too? if so while your in there, inspect for cracking.......just sayin'...
Fred B
Rate This Thread:
