December 2025
Like Tree1Likes
  • 1 Post By
Old 06-28-2012, 10:11 PM
RodKnock's Avatar
Originally Posted by wideglidejoe View Post
If anyone has it handy, is the Weiand 7282 really that low on the list on performance numbers?
Tested on a 428CJ w/410 HP and Torque and a 390 Stroker, the Weiand 7282 finished last in Torque and 2nd & 3rd to last on HP covering about 30-50 intake manifolds for those two engines. So it "finished poorly."
It appears that the plenum divider is not complete, because of two large holes (1.5" X 4") are cast into the divider. "The large holes essentially turn the plenum of this manifold into a single space, rather than a split plenum..." And "large plenums have been associated with loss of midrange."
Old 06-29-2012, 04:54 AM
Somehow I didn't see the part about you having a Performer RPM and a Weiand....
I'd use the Performer RPM. Sweet intake. I just made 575hp and 630 lb-ft of torque with one on a 482.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 06-29-2012, 11:28 AM
Cobra Make, Engine: FFR MK III,462 FE/TKO 600, IRS w/3.27
Default Thanks again for the replies and info!
Thanks to ALL of you who replied in this thread!
From my most recent post;
RodKnock, thanks for referencing your book for me, that helps!
blykins......Brent, isn't it? Thanks for the clarification, I'll use the RPM. Now all I need is a 482 or 496 to put it on. I'm still chasing a lead on a 427 block, otherwise I'll be building a 445 FE.
Thanks to all,
Have a great 4th!!
Joe
Wideglidejoe
FFR#6143 Mk III: FE 462" w/four 48 IDA Weber's w/TKO 600 .82, IRS w/3.27, 17" Team III's w/245/45's & 315/35's. Gas N's.
Picked it up end of Aug '08
First start May 12, '10
First go kart May 26, '10
Tag & title 5-26-11, driving in gel coat
Painted Nov 2015
'05 Harley Wide Glide (60 hp stock, now 107 hp & 107 ft/lbs at wheel. Mid 11's in the 1/4 mi.)
'55 Bel Air hot rod project (WIP)
Rate This Thread:
