  #21 (permalink)
Old 08-06-2012, 09:38 AM
FWB's Avatar
FWB FWB is offline
is that what they call it now....hehehe
stop in anytime....
Fred B
  #22 (permalink)
Old 09-26-2012, 08:36 AM
Cobra Make, Engine: Genuine original Unique MotorCars 427 S/C, with a Genuine original Ford 427 Side-oiler.
Send a message via Yahoo to Cobranut
Default PCV Routing
I run my pcv in the right v/c with a homemade oil separator between there and the port at the back of the manifold, just below the carb flange.
I have a K&N breather filter in the driver side v/c and a solid plate covering the lifter valley opening at the rear of the manifold.
This causes fresh air to be drawn all the way through the engine, removing condensation and blowby gases that could contaminate the oil. It also keeps the plumbing simple and I have no troubles with oil vapor blowing out the breather.
Originally Posted by bret a ewing View Post
I have a Blue Thunder intake manifold on an FE 482 block and have to install a PCV.
The question is, where is the best place to route the PCV line coming from the passenger side valve cover.
I will be using an Earl's alum breather on the drivers side valve cover and an Earl's alum breather with integral PCV/an-6 on the passenger.
** There is no rear carb port and I dont have the hood clearance to add a carb plate, even a Boss 302 style.
So I have 2 options:
Do I use the plug on the manifold underneath the rear of the carb...........or drill and tap the cover plate (covers the 1 1/2" rear port - currently has the 5" high FE breather on it) for the fitting.
Additionally, if I use the smaller hole below the carb should I reinstall the rear manifold cover plate to increase vacuum, or can I leave the breather on?
Sorry for the long question, looking for someone who knows or who has already done the experiment so I wont have to, thank you.
Best, Bret.
David
  #23 (permalink)
Old 10-01-2012, 06:55 AM
Cobra Make, Engine: Look-a-like cobra POS
David,
That is precisely how I am venting mine. Wont know how it will work until the motor is (re)installed.
Thanks for the help.
Best, Bret.
B. Ewing
  #24 (permalink)
Old 10-01-2012, 09:07 AM
FWB's Avatar
FWB FWB is offline
Bret,
if you ever need anything or a hand let me know. i have a good supply of ford stuff too if you get into a pinch.... lots of FE stuff,.. lots of small block stuff.
Fred
Fred B
  #25 (permalink)
Old 10-01-2012, 09:23 AM
Hi Fred,
You are too kind, nice to know assistance and parts are so close, I will pass along the parts supply to the boys.
We are headed to OC Maryland this weekend for Endless Summer. Give me a buzz sometime and you can help me keep the keg fresh in the beermeister.
PM sent with contact info.
Best, Bret.
B. Ewing
Rate This Thread:
