Like Tree1Likes
  • 1 Post By Keithc8
Old 06-08-2014, 02:01 PM
Default New 496C.I. Cammer build
Finally got all the parts together to start a 496C.I. Cammer FE build. Pond 4.310 bore with a 4340 4.250 stroke steel crankshaft. Premium pump gas friendly but customer plans on switching over to natural gas later. Coon KC CNC ported heads with Ferrrea hallow stem valves coated with Titankote C14 coating for durability and to hold up to the heat of the natural gas with Pac Bee Hive valve springs. Dailey Engineering dry sump oil pump and oil pan. We will use a Hilborn electronic stack injection set up with the Fast ECU and wiring harness. We will fully port the intake as needed matching to the heads and stack units. Making the opening at the stack bigger than the stacks has shown to help reversion and idle quality plus help HP.
This will be a unique build to say the least and we will dyno on gas and the customer will have it chassi dynode and tuned when he goes to the natural gas. That will be interesting for sure. We will follow up with some pictures and more information as this comes together. This should come together in the next month or so.
Thanks, Keith Craft
mjl likes this.
Keith C
Old 06-08-2014, 03:18 PM
750hp's Avatar
Looking forward to seeing it come together Keith. For the overall cost of this motor, would you normally recommend that the pistons and camshaft be changed out from the pump gas specs to maximise the high compression combination that natural gas allows?
Craig
Old 06-08-2014, 06:37 PM
Here is what suggested to our customer on the compression. I have no ideal how this natural gas deal will work for him so we suggested staying in the 11 to 1 range so if he has to stay with premium pump gas or a little better he can. The pistons will be plenty strong to handle the job being Diamond custom for the application.
Thanks, Keith
Keith C
Old 07-17-2014, 11:56 AM
http://s454.photobucket.com/user/Keithc8/library/496
Keith C
Old 07-17-2014, 03:41 PM
legenmetals's Avatar
Chrisman's Cammer Candy Store
The shiny cammer is going into my ccx. It has a modest build. Stock stroke with Crower billit crank,Robert Pond block,Bill Coon heads,9.5-1 compression. Modified Hilborn but we are using the Holley controls. We are using a crank trigger for the Holley set up and using a Hunt magneto style distributor but with our own internals.
Old 08-08-2014, 10:42 AM
Default Build Complete
The 496ci Cammer is complete and dyno tested. The engine made 774.8 hp @ 7000 rpm and 654.6 ft/lbs at 5100 rpm with a conservative street tune. Stay tuned for Dyno Video and Pics.
Keith C
Old 08-08-2014, 01:24 PM
IMG_30251_zps50a66469.jpg Photo by Keithc8 | Photobucket
Keith C
