Old 08-01-2014, 01:56 PM
crenbbf's Avatar
Default FE core drain plugs
Hi again
One of our core drain plugs took a beating to get it out, so we trashed it on the assumption replacements would come in the core plug kit.
What are our options?
On the same note how do you actually measure these npt plugs?
cheers Kiel
Old 08-01-2014, 02:14 PM
FWB's Avatar
FWB FWB is offline
Originally Posted by crenbbf View Post
Hi again
cheers Kiel
which plugs? the large ones on the side of a 427 the threaded ones?
Fred B
Old 08-01-2014, 02:28 PM
crenbbf's Avatar
Hi
Wish it was, no our engine is a 390 based motor, there the small drain plugs near the engine mounts. The drains not the core plugs.
cheers
Old 08-01-2014, 02:35 PM
FWB's Avatar
FWB FWB is offline
oh, thats an easy one. they are 3/8 NPT.
i use a 45 degree adapter and put radiator petcocks in there that way they point down.
easy to drain to change a thermostat or a hose with out alot of mess
npt is measured by the inside diameter of the pipe they go on...so really with plugs hard to tell unless you recognize them or have a chart showing their actual sizes
here..
Fred B
Old 08-01-2014, 02:51 PM
crenbbf's Avatar
Thanks Fred
Much appreciated
cheers Kiel
Old 08-02-2014, 11:08 AM
You sure they're 3/8"?
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 08-02-2014, 11:17 AM
crenbbf's Avatar
Brent
Same as the oil galley plugs adjacent to the cam plug
Not 3/8" then?
cheers Kiel
Old 08-02-2014, 11:56 AM
I'm thinking it's a 1/4...
Old 08-02-2014, 11:59 AM
crenbbf's Avatar
here you go
cheers Kiel
Old 08-02-2014, 12:01 PM
Everything I've ever seen was 1/4 pipe. Use brass next time. Even if it gets stuck , it's easier to drill and tap out.
Old 08-02-2014, 12:12 PM
FWB's Avatar
FWB FWB is offline
hmmm, maybe.....use the chart....
Fred B
Old 08-02-2014, 01:05 PM
crenbbf's Avatar
Ok had a measure and according to the chart they are 1/4" NPT
Kinda funny really considering the bit you measure doesn't actually get into the block
Good call regarding brass plugs even found some on our side of the pond
cheers Kiel
