Like Tree3Likes
Old 01-25-2015, 09:10 AM
I did the autopsy on my son's 4.6 DOHC Lincoln after a broken valve spring dropped an exhaust valve. I was impressed with the guides that tension the chain and keep it from oscillating or vibrating. They obviously did not want the chain to have the slightest whipping action. I was also amazed that the plastic material looked new after 120K miles.
If you think about it, a slight whipping action in a chain would cause the distance of chain between the sprockets to increase. The shortest distance between any two points is a straight line, and a squiggly line is always longer.
The old books talk about chain stretch on the old cammers causing a timing difference in the two cams. I suspect the long unsupported chains whipping also contribute. On that long of a chain I'm sure there is length change do to thermal expansion of engine and chains. That has to have an impact as well. Perhaps a good hard look at the Modular design would inspire some design improvements for the old cammer.
My memory is that it is one long chain going from center cam, to left head to right head and back to the center cam. Maybe it was the crank, but I think it is the center cam. Anyway a short chain from the center cam to one head and another chain going to the other head would seem to solve a lot of problems.
Old 01-27-2015, 06:42 PM
Cobra Make, Engine: CSX4000, 427
well, I don'y know. A SOHC is a beautiful engine, especially to an engineer like me. Seen them, never owned or ran one. But todays wedge engines, with more modern heads and port work, I think can come close enough to cammer performance for alot less money and headaches. Although I fanatasize about a cammer, I doubt I'll ever have/build one.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
Rate This Thread:
