Old 06-13-2015, 11:39 AM
car4jim's Avatar
Cobra Make, Engine: Kirkham, 427 side oiler
Default Oil Slinger - Do I need one?
I'm working with a Robert Pond aluminum 427 side-oiler engine. I'm doing some engine work to reseal the engine. When I removed the front cover, I discovered the engine went it's first 4000 miles without a front crank oil slinger. I've read some forums that suggest you don't need this and some say you can't use an oil slinger with a double roller steel gear. I don't believe there was an issue leaking oil from the front crank seal, not sure due to other leaks. Should I buy one and install, or go without, or won't work with current engine setup. Feedback appreciated.
Old 06-13-2015, 06:41 PM
RET_COP's Avatar
Cobra Make, Engine: Fordstroker 408w custom solid roller-Craft ported Brodix 17*heads-CFM ported Vic Jr. intake-1 3/4 primaries- 575hp-TKO-600RR Liberty upgrade- -Moser 8.8 trutrac-McLeod Street Extreme--QA-1-Wilwood brakes, Classic Chambered 3" Cobrapacks, Avon's
I put in a double roller and left the slinger out. Going on third season, no issues. Many other have done the same with no issues
Lou
Old 06-13-2015, 07:28 PM
I have never used one and I've built a poop load of FEs....
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 06-14-2015, 07:07 AM
car4jim's Avatar
So...is the purpose of the oil slinger to spin oil up on the cam gear, or to keep oil from reaching the front timing cover oil seal?
