Like Tree9Likes
  #41 (permalink)
Old 09-30-2016, 05:43 AM
I run the cam timing pretty advanced on a lot of my engines. This cam was ordered with a 110 LSA, on a 104 ICL. It degreed in at 103.25. When we run that advanced, you can really see how piston to valve clearance is affected. The trend is that when you advance cam timing, intake valve clearance decreases and exhaust valve clearance increases. As you can see in the next two pictures, it's very apparent: intake valve clearance was .100" + head gasket thickness, exhaust valve clearance was a whopping .300" + head gasket.
Valve springs are set up at a nominal 1.900" install height. Valve spring pressures are tested based on install height, full lift, and coil bind.
And if you've never seen a factory MR intake port that approaches 320 cfm, then here's your chance....
  #42 (permalink)
Old 10-01-2016, 08:15 AM
Strange, I never actually used clay to check valve clearance, and I new it was the best way. I have measure the valve stem movement with the valve spring off. In my defense, that was back in my puppy days.
I was surprised how close the intake valve comes to the notch in the piston. Especially surprising to me after seeing the exhaust is a mile away, in comparison. I never gave clearance radially from the valve to the piston cut any thought. Measuring the valve stem travel, only measures one dimension. The edge of the valve may only have 0.002" clearance from the cut in the piston, and that method of measure wouldn't tell you that. That would get ugly when things heated up.
I learned something today. I'll never miss this step again.
  #43 (permalink)
Old 10-01-2016, 08:21 AM
On the intake, I have been surprised how many people talk like they believe aluminum equals better flow. Aluminum is a nice soft easy metal to work with, but the material has nothing to do with flow. Cast Iron can flow just as much; it is just harder to machine and work with.
  #44 (permalink)
Old 10-01-2016, 09:03 AM
If the clearance starts getting close, then it's best to use a degree wheel and dial indicator to check clearance as the clay can move around and stick a little. Typically the intake valve will be closest at around 10° ATDC. The exhaust valve will be closest around 10° BTDC.
As you mention though, the clay will show the radical clearance and has saved my butt a few times. Have had to adjust the reliefs on some custom pistons before.
I don't think I have heard anyone say that the material makes the flow different, but typically, your aftermarket heads are all aluminum, and they are the ones that will most likely yield aftermarket performance...
I have access to one of the best head porters around though....
  #45 (permalink)
Old 10-01-2016, 07:07 PM
Gaz64's Avatar
Yes, it certainly is the best way.
I have had one engine where the valves were increased to almost total bore diameter, 52% and 43% and the block needed to be notched for clearance for the exhaust valve.
Same for making custom valve reliefs in the piston.
Observe how blykins has about the same radially as it does vertically.
  #46 (permalink)
Old 10-02-2016, 07:00 AM
No, me either, but I have had people dismiss cast iron as low performance junk and act like aluminum equal performance. It's the porting not the material it is made from. There are some aluminum heads sold that are not significantly different from the factory cast iron.
  #47 (permalink)
Old 10-02-2016, 07:03 AM
davids2toys's Avatar
As promised....
Everything has went together pretty much without fuss, with the exception of the oil pump pickup. I used a Canton oil pan with Alan's build and the pickup that is recommended for the pan showed 9/16" of pickup clearance when I mocked it up and measured. Luckily, I had a Moroso pickup on the shelf that showed a more desirable 5/16" when I tried it. So, it has a Canton pan with a Moroso pickup. I also had to dimple the oil pan around the rear rail so that it would sit on the block without contacting the rear main cap bolts.
This build is really nice, I'm jealous.
Back to the Canton oil pan. Are you running the RR pan or the standard T pan? Wind-age tray? This winter I am hoping to finally switching out my regular pan for the RR pan with the dipstick on the right (Passenger) side.
Also not aware of any dimpling that needs to be done. I installed a Canton pan on my last 428 with no issue. Is the 427 different?
Along with my oil pan switch, I will be removing anything with a gasket because I am leaking oil from everywhere. A real ugly mess! Everything has been sitting on a shelf for three years now...LOL. Just not enough time!
Dave
  #48 (permalink)
Old 10-02-2016, 07:10 AM
Yes that is what caught my eye. A picture is worth a thousand words.
Then when you think of all the head and piston manufactures (especially twisted wedge and Cleveland types SB), the valve reliefs and heads are not always going to match.
Just one of those light bulb moments for me. I'm not afraid to admit I learned something or didn't truly understand it in the first place.
Even though I was aware the other dimension (radial) existed, I always thought one dimensional in valve clearance. I was fully aware of valve shrouding by the cylinder wall, and that some applications people notched the top of the cylinder wall. It just never clicked that the radial clearance needs to be checked until I saw that picture.
  #49 (permalink)
Old 10-02-2016, 12:18 PM
David, Canton has two front tee sumped pans. They both look exactly alike, but one has all the trap doors and one doesn't. This one doesn't.
If you are using aftermarket rear main cap fasteners, chances are something will have to be done to whatever pan you're using. Even ARP bolts stick high enough up that they will hit the pan rail. Some guys mill the bolts down, I find it easier to just dimple the pan rail from the inside. Also, a factory 427 block has a small pipe plug near the block rail. The pan rail hit it.
I don't use windage trays for street engines. No need in it. You won't see any horsepower gains on the dyno and it serves as yet another gasket that could cause sealing problems. In this case, it would have made the pickup clearance even worse...
  #50 (permalink)
Old 10-03-2016, 06:13 PM
Yes, I have both the pans. Very good point about the Windage tray and the extra gasket being a potential leak. maybe I will sell it and just install the RR pan with all the doors. I guess I should also find a way to measure the pickup to the bottom of the pan also.
I will also look for any interference.
Thanks for the great info Brent.
Dave
  #51 (permalink)
Old 10-04-2016, 05:07 AM
AC Ventura's Avatar
Cobra Make, Engine: AC Cars Limited, 302 EFI
I continue to be impressed with the level of expertise and care taken with these FE builds.
  #52 (permalink)
Old 10-05-2016, 03:50 AM
Head gaskets are on and heads are on. Need to re-torque them and I'm waiting on the intake manifold to come back from being blasted....
  #53 (permalink)
Old 10-07-2016, 02:21 PM
Almost ready to stick a fork in it....
Forgot that I didn't have a breather to fit onto the front oil fill tube and I need to run and get a few bolts for the intake manifold that are a little different length than normal.
Other than that, need to do a final oil pump prime (already spun it and checked for leaks this morning), put the plug wires on, and it will be ready.
Tentative dyno day is the 21st. Alan doesn't have his car yet and I'm gonna try and take two engines with me.
Old school cool....
  #54 (permalink)
Old 10-08-2016, 04:17 AM
Gaz64's Avatar
Come on Brent, valve covers sitting on already, no pics of valvetrain?
The one part I've been waiting to see.
  #55 (permalink)
Old 10-08-2016, 05:26 AM
Cometic head gaskets....
Morel lifters and Cometic intake gaskets....
  #56 (permalink)
Old 10-09-2016, 03:25 AM
Gaz64's Avatar
Nice, very nice, should go well,
  #57 (permalink)
Old 10-09-2016, 04:53 AM
DanEC's Avatar
Gasdoc (Alan) hasn't been seen on the forum since June. ERA builds take awhile but most owners typically have some questions and observations along the way in the meantime. Hope all is well.
ERA 782 Running
  #58 (permalink)
Old 10-09-2016, 05:17 AM
Well, I suppose he could have lost his CC username/password, but you'd think he'd pick up the phone and chat with Brent. I sense there is a problem.
  #59 (permalink)
Old 10-09-2016, 07:10 AM
DanEC's Avatar
Are those stock Ford rockers or an aftermarket look alike? Kind of surprised 427 adjustable rockers weren't used so lifter pre-load could be set.
ERA 782 Running
  #60 (permalink)
Old 10-09-2016, 08:59 AM
Alan is ok, he's been emailing me.
The rockers are new factory replacements. The non-adjustables work just fine with careful pushrod length measuring. The lifter preload is built into the pushrod length. I have been doing a lot of builds with factory non-adjustable rockers. They are very light without the adjuster and nut hanging off the back and are beefy enough to handle hydraulic roller spring pressures.
The shafts are new as well and the stands are reconditioned. The end stands are necessary IMO, and come from Precision Oil Pumps.
120mm likes this.
