Like Tree3Likes
  • 1 Post By T Spoon
  • 1 Post By
  • 1 Post By T Spoon
Old 04-23-2017, 03:37 PM
Cobra Make, Engine: Kirkham 427SC Stack injected side oiler
Default 427 Side oiler strange hole in deck
I just pulled the motor from my Kirkham 427 due to a significant oil leak. It was coming from the head gasket area at the rear passenger side corner. Block code is C5AE-H.
When I pulled the heads, this is what I found. The mystery holes had been filled with some kind of sealant by the engine builder.
What are these holes?
*13* likes this.
Old 04-23-2017, 08:55 PM
Cobra Make, Engine: Contemporary Classics, red white stripes
Default 427 sohc
Looks like oil drain holes for a 427 SOHC.
Old 04-24-2017, 03:03 AM
Yep, it's a cammer block.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 04-24-2017, 06:32 AM
Default Thanks
Thanks for the info. Should I try to plug the holes properly or just sell it and start over?
Old 04-24-2017, 06:37 AM
Well, I certainly wouldn't sell it.
In times past, I have dealt with this in a couple of ways....
1. Find a cup plug (like a freeze plug) that fits the hole, put a little silicone around it and drive it in.
2. Tap the hole for a pipe plug (requires engine to be torn down to bare block).
In either case, whatever plug you make needs to be under the deck surface of the block when installed.
Old 04-24-2017, 09:17 AM
CHANMADD's Avatar
What difference...it's got no pressure, just a drain.
Old 04-24-2017, 10:05 AM
It's got splash and vapor pushing up at it....
Old 04-25-2017, 07:14 AM
Default You win!
Those holes are drainbacks for a 427 SOHC cylinder head. For your purposes you can tap in a small freeze plug with some silicone and it'll be fine. But that block might be worth a bunch on money to somebody building an original Cammer!
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
Old 04-25-2017, 08:54 AM
cycleguy55's Avatar
Agreed. I'd be inclined to sell the block to someone building a cammer and replace it with a BBM (or other) block. Genuine SOHC blocks are scarce / rare, and would be highly prized by someone looking to build a cammer.
Brian
Old 04-25-2017, 10:23 AM
1795's Avatar
I would concur with Brian and Barry, explore what that block might sell for and if there is interest in it and then compare what a new block might cost. It might put some money back in your pocket.
Old 04-26-2017, 10:23 PM
Default Thanks for the replies
Thanks to everyone for the thoughtful replies. I'm sure i can find a way to reliably plug the hole but I would feel better if it went to someone who valued it and wanted to build a cammer engine. I'm not ambitious enough to taken on a cammer in Kirkham project and it does not feel right to hide it in a regular FE engine.
cycleguy55 likes this.
Old 04-27-2017, 09:53 AM
legenmetals's Avatar
Cobra Make, Engine: contemporary(2) one with 427 sohc and one with 427 center oiler
I may be interested in your block, What is the condition of your block? What kind of history as far as use and prior machining do you have available?
I am located in San Diego.
