Like Tree8Likes
  #41 (permalink)
Old 11-29-2017, 03:07 AM
Now, there are a lot of heads that are very similar, within a digit that it could be also. Sometimes casting numbers are hard to read.
Could it be a C6AE-R? Or a C5AE-F?
Are you sure they're cast iron?
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
  #42 (permalink)
Old 11-29-2017, 04:02 AM
Definitely F.
  #43 (permalink)
Old 11-29-2017, 04:03 AM
Definitely C6?
Stick a magnet to it....
  #44 (permalink)
Old 11-29-2017, 05:09 AM
Definitely C6?
Yep magnet sticks, cast iron.
  #45 (permalink)
Old 11-29-2017, 05:24 AM
Can you post a picture?
I think you actually have a C5AE-F head, which is a factory 427 medium riser head.
  #46 (permalink)
Old 11-29-2017, 07:28 AM
What does that mean? I had a ford tech look at them and he thought they might be 428 heads...... Is that possible? I still haven't figured out how to down load pictures or I would be glad to do it. Back to the heads how good are they and what would be the aluminum replacement? I tripled checked the heads again and they are cast iron and the id is (C6AE-F). Thanks for all your time.
  #47 (permalink)
Old 11-29-2017, 07:35 AM
Can you email or text me a pic? 502.759.1431
It's a mystery as to whether or not that head actually exists. Most believe that the molds were worn out and it's actually a C5 cast number, which would make it a factory 427 MR head.
If it is, then the chamber sizes on those were in the upper 80's, which would mean that you would need to find a replacement head similar to that size. The Pond heads would be the only ones that I could think of, otherwise your compression ratio would go sky high with an Edelbrock, BBM, Survival, etc.
  #48 (permalink)
Old 11-29-2017, 12:19 PM
Ok, I will send you some photos this evening. Thanks
  #49 (permalink)
Old 11-29-2017, 03:01 PM
joyridin''s Avatar
Hurry up! The suspense is killing me!
  #50 (permalink)
Old 11-29-2017, 03:19 PM
Hopefully Brent will post them as well. Personally, I'm rooting for a never-been-seen before, one time only, iron FE head.
joyridin' likes this.
  #51 (permalink)
Old 11-29-2017, 07:15 PM
Brent, I think I screwed up. My 70 year old eyes aren't what they used to be. I do believe the casting is C5AE- F. Sorry. Now that is solved what can you tell me about my heads. What manufacture would you recommend? Sorry for all the confusion actually my wife caught it. She was right but l'll never tell her that.
  #52 (permalink)
Old 11-30-2017, 02:57 AM
Got your email, yes it's a C5AE-F head. Factory 427 medium riser.
Now, for the kicker....
I won't be able to tell you exactly what you need until those come off. In factory form, the chamber sizes were supposed to have been 88-91cc. That means that only a Pond aluminum head would be a good substitute, in order to keep your compression ratio down.
However....
The last 427 I built for Alan Carter, a forum member here, used those heads. After cleaning the decks up and a valve swap, they were at 73cc.
You can never tell what's been done to a block, or to a pair of heads in the last 50 years. They may have been milled to death or they may be factory fresh.
I think if you're ready to do a swap, I would suggest mothballing the car for the winter, then have your shop pull the heads and cc the chambers. That way, we can approach this as a methodical engine builder instead of throwing parts at it.
Buzz likes this.
  #53 (permalink)
Old 11-30-2017, 03:25 AM
Buzz's Avatar
Thumbs up
Frank honesty and consummate professionalism once again from Brent. Credibility as a person and an engine builder is off the charts. Several thumbs up!
Tropical Buzz
  #54 (permalink)
Old 11-30-2017, 04:32 AM
joyridin''s Avatar
Bummer! Oh well....back to watching The Curse of Oak Island!
  #55 (permalink)
Old 11-30-2017, 05:25 AM
Thanks to everyone who took part in this discussion especially Brent you all have been very helpful. Now I know what I have and what direction I'm going.
Rate This Thread:
