Like Tree1Likes
  • 1 Post By
Old 05-11-2023, 05:42 AM
Cobra Make, Engine: Everett Morrison FE 428
Originally Posted by eschaider View Post
Fix the problem correctly. Rear main oil leaks only get worse, not better. Attempting to jury rig a PCV system to draw a vacuum in the crankcase will not work as Tommy already explained. Jury rigging a fix like that will only allow the problem to get worse, and in the bigger picture, is a waste of time. Fix the problem correctly.
You really know how to shut a person and a conversation down don’t you
Old 05-11-2023, 08:14 AM
twobjshelbys's Avatar
I was originally going to propose that a complete fix could be had by adding enough vacuum to pull air in through the seal.
Tony
CSX4005LA
Old 05-11-2023, 09:33 AM
eschaider's Avatar
No one is forcing you to do things the right way. This is your car, after all, and by definition, because it is yours, and you pay all the bills, you get to make all the calls. That means whatever you decide is automatically going to be right, for you, until it doesn't work or fails — again.
That does not mean it will be right for everyone else. Some members of the everyone else contingent may actually embrace the same logic that you do and follow your lead. Like you, their car and their call — which makes it right for them also.
For the rest of us who want to embrace the 'generally accepted' right way of fixing a rear main oil seal failure, your approach falls more than a little short of the mark. But, of course, for you, that is not an issue because you have already decided it is not.
The rest of us, well — not so much ...
Old 05-11-2023, 10:59 AM
Cobragene -- if the leak is not a gusher, just put a discrete little diaper on your bell housing like I described in this thread: FE vs Roush vs Blueprint
Here are two pics:
