Old 06-14-2002, 08:27 PM
Cobra Make, Engine: Custom built Excalibur 351C
Default Approx value?
Last night I saw a both a 3 x 2 manifold with carbs and air cleaner and a 2 x 4 manifold with carbs and air cleaner for an FE (427?)
What is the approx value?
Note: both intakes were Aluminum and appeared OEM
Old 06-17-2002, 07:40 PM
SCOBRAC's Avatar
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
well.. the 3x2 you describe did not come on a 427 in any form of Hi-Po option from Ford.. It did come on 390's ans 406 FE motors and you may have seen some on a 427's but those would not have been the way to go for a 427..
Value?? Depends on condition.. Polished aluminum with rebuilt carbs.. With new linkage.. Maybe $1500.. Basic running unit maybe $800.. Poor condition maybe $250-500..
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
Old 06-17-2002, 07:47 PM
SCOBRAC's Avatar
The 2x4 units are out there.. most are not original and if they are they are not cheap.. But manifolds are pretty availiable for between $300 and $1,000 (but cheaper repo's are out there for $500) and new carbs can be gotten from Holley for $200 ea.
Good luck,
michael
Old 06-18-2002, 06:49 PM
Exclamation 3 duces
I have a aluminum intake with 3 original 2-barrel carbs and oval air cleaner. Carbs should be rebuilt. Believe this unit not used for at least 10 years. It's been in my garage that long! Also this unit for a Galaxie not a T-Bird. Interested?
sn8ke
Old 06-18-2002, 07:19 PM
SCOBRAC's Avatar
I looked up the OEM prices in 1966 for both the set-ups listed.. The 3x2's went complete for $264.. The 2x4 went for $249 with 550 carbs...
A lot of money back in the day.. At those prices adjusted for inflation these units should be over two grand today..
michael
Old 06-18-2002, 08:29 PM
Default Thanks!
The guy that had them wanted to sell but had no idea of value.
I told him I'd check with you guys!
I'll pass it along.
Thanks
Rate This Thread:
