Old 07-19-2002, 10:04 PM
Default 428 CJ Cam Advice
I am just finishing up my 428 CJ for my new Superformance. When I brought the engine it had been in a show truck to replace the stock 390 that was in it. The guy who did the work before me set it up for torque and used Com Cams 270H hydraulic cam set. I am wondering if the 292H would be a better fit for a Cobra. Any problems with vacuum??
Thanks in advance for any ideas...
PULNGZ in Canada
Old 07-19-2002, 10:20 PM
Cobra Make, Engine: Superformance #1287 -- Shelby Aluminium 504ci FE SOLD 2007..--------Superformance #2305 Ford FE 482ci Sideoiler Presently
I have a 428 in SPF 1287. I used Comp Cam 280H and had no problem with vaccumn for brakes. I switched to 282S and it also works well. It has almost 10" vaccumn at idle.. Steve
Steve McD
Old 07-20-2002, 10:30 PM
Cobra Make, Engine: ERA, 496 Tunnel Wedge
Send a message via AIM to My427stang
I am a firm believer in agressive cams in an FE, especially longer stroke like a 428. The 280H is mild, I run one in a 390 truck, I dont think you'll be happy. The 292 will be agressive, but should be fine in a light vehicle. If there is one between the two, it may be the way to go, but if it were mine I'd buy the 292
BTW I run a 306 in my Mustang and its streetable in a 427 and they are less tolerant with the shorter stroke (although its really radical, probably too much for yours)
The difference in mid range between the 292 and 270 will be amazing, that cam is WAY too small, even for a truck
Go for the 292 and it will be fun or if they have a 288 it would work too. My guide would be 240 degrees duration @ .050.
1994 ERA Cobra, 452 side oiler, C5AE-F, Tunnel Wedge
70 Mustang Fastback, EFI 489 FE TKO-600, too much to list
71 F-100 4x4 EFI 461 FE restomod
Bullock's Power Service, LLC
Concours and performance engines by appointment only
https://www.facebook.com/BullocksPowerService
Old 07-24-2002, 08:52 PM
Send a message via AIM to hdheritage97
Default Me too
I also ran the 306 cam in my 68 GT500KR and I absolutely loved it. However, brake vac was a bit on the low side....lol. But the bottom line was that the car ran like a raped ape. My Cobra has no power brakes so vac isn't an issue for me but I agree, go for as much cam as you can and still have it drivable. Remember, a good cam is one of the easiest ways, if not the easiest, to attain HP and Torque gains, just my opinion.
Cliff
" Like my Grandfather always told me, if you are truly good at something there's no need to brag, others will be sure to do that for you "
Old 07-26-2002, 09:52 PM
Thanks for the advice. I think I am going with the 292H...
PULNGZ in Canada
Old 07-28-2002, 02:23 AM
I run an Elgin cam which has stock Ford numbers from 1964. My FE is a 390 bored 60 over with ported heads and 428 valves (2.09 and 1.66) . The cam numbers are advertized 324 deg. lift is .524, duration at 50 is 245. This is a solid lifter cam and the power band is about 3000 to 7000rpm. As said from above it runs like a raped ape.
