Old 06-03-2003, 12:40 PM
Whew!! Thanks Ernie
Old 06-03-2003, 07:44 PM
Cobra Make, Engine: Classic Roadster with 427 center oiler
I'm with Clois Harlan. Check to see if the oil lines are not connected to the block adapter backwards.
Paul
life is short: eat dessert first !
Old 06-03-2003, 08:15 PM
Bill,
Sorry to hear about your problem. Hang in there Buddy. Let us know what you find when you blow it apart. In addition to checking the plate at the block, take a look at the plumbing on your remote filter, people have starved engines plumbing that in reverse. The center line is out and the outboard line is in. Somehow this always seems intuitively wrong to me so I check it 15 times after reconnecting.
Good luck. Steve
Old 06-03-2003, 09:31 PM
HighPlainsDrifter's Avatar
Hi,
Sorry to hear about your trouble.
You have a mechanical cam, so it needs proper adjustment with feeler gauges, check the cam spec sheet for clearances, such as .022 intake and .024 exhaust , adjust when cold. If your clearances were too tight then when the engine warmed up, the clearances would get tighter ,cause spring bind and destroy your cam.
Also why are you running a mechanical cam, are you going to race it? The hydraulic grinds are just as powerful as the mechanical grinds and are more street friendly and don't need to be adjusted every time you take it to the track.
Perry.
Old 06-03-2003, 10:55 PM
Bill,
Did you check your installed heights and compare to the height at which the springs bind? Given my cam lift and installed heights even if I adjusted my lash at 0.00" cold, my springs would not come close to binding after things warmed up. I think after you get things torn down you will have a good idea as to what went on.
Good luck, Steve
Old 06-03-2003, 11:02 PM
Also, did you break it in with both the inner and outer springs in place?? That might have contributed to the lobe/lifter wear but the broken lifters.......................................
Steve
Old 06-04-2003, 04:28 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Venom S, if I didn't know any better, I'd have to say Comp Cams owes you and engine.
You will need to get a metalurgist to confirm the lifter cases were not hardened.
Try to look at the bright side... you needed to have something to do for the next two or three weeks... right.
Good luck.
Old 06-04-2003, 07:27 AM
Thanks everyone.
Worked on the motor some more last night in preparation for removing it tomorrow evening after work. I tried to turn the oil pump via the shaft and it fell straight through to the oil pan Now I'm wondering if somehow, the shaft or oil pump failed and that contributed to my engine failure. I guess I will know more when I pull the pan.
I'm now looking for a nice nydraulic roller cam and will also get matching springs to ensure no problems arise.
Steve-
Are you going to the Sandwhich Factory Saturday?
Bill
Old 06-04-2003, 08:21 AM
Rick Parker's Avatar
Before you disconect everything and yank the engine, take aminute to look at the plumbing for the remote oil filter & cooler. As Clois posted previously, if oil is being heavily restricted this would cause this type of damage would result. Specifically, be certain that the hose carrying oil "OUT" of the engine is going "IN" to the filter, then "OUT" of the filter to the cooler and then back to the engine. If you have an oil cooler it should be replaced and not reused. There is no way to clean it successfully. Be sure to flush all hoses before reuse. Fill the filter, cooler and if possible the lines with oil before firing next time. Good luck
Let us all know what you find. What a way to spoil an anticipated event!!!
Old 06-04-2003, 08:53 AM
Bill,
I'll be there a bit early and will have to leave by 12:30. With any luck my car will be there to.
If your oil pump drive shaft broke you would have noticed the pressure drop to zero.
Hang in there, Steve
Old 06-04-2003, 10:45 AM
joea's Avatar
Cobra Make, Engine: ERA #676, 428SCJ (2x4), TKOII
The suspense of finding out what caused this is just as bad a waiting for my ERA!
"There are 10 types of people out there....the ones that understand binary and the zeros that don't."
Old 06-04-2003, 10:47 AM
Mr.Fixit's Avatar
Next time, prelube the motor until you see oil dribbling out of the tops of the pushrods, that way you know it is circulating. You can't clean metal debris out of an oil cooler, you replace them.
  #33 (permalink)
Old 06-04-2003, 10:58 AM
zipzip's Avatar
Cobra Make, Engine: Midstates work in progress, personally built 302
Sorry to hear about your problems!
I think that the pump drive shaft can come out of the pump and drop into the pan if the retaining washer is not in place. In my engine, it is like one of those push caps on a kids toy (you know the ones that you hammer and hammer on until they are bent and mangled but holding - then you realize you forgot a small part and have to somehow pry them off!). Anyway... if that washer drops too far down the shaft, the shaft will be able to pull up and out of the oil pump, then kerplunk, into the pan.
I think the broken part of the lifters look like a brittle fracture, which either means a cast part, or some sort of heat treatment. Even hard parts will wear with no oil. The lifters do not show a lot of heat though, so I think oil was present, but maybe not in the quantity needed. You noted some "supplier problems" - could the lifters have been out of tolerance on the OD, allowing them to "cock" in the lifter bore and bind up? This might explain the lack of damage to the pushrods. Or could they have been allowed to come out of the lifter bores in the block enough to bind, similar to pistons coming out of the cylinder if you get too much stroke on the crank?
Good luck and best wishes!
You might be a redneck if you think the National Anthem ends with "...Gentlemen, start your engines."
  #34 (permalink)
Old 06-04-2003, 11:33 AM
Clois Harlan's Avatar
Venom S
I have way to much experience at this stuff lately. I talked to my machinist last night about your situation and he told me to tell you to leave your valves and springs in tact and take your heads to your machinist and maybe he can shed some light on this catastrophy.
Hang in there and be sure to mic and magnaflux everything before you re-use it. Pretty cheap insurance. If you are considering another hydraulic cam I would suggest a Crane if you can find the grind you like or go with a Solid lifter Cam.
If you want to feel a little better about your situation, you can go back and read some of my post over the last 12 or so months.
Clois
"Let's roll"
"Be part of Something Good
  #35 (permalink)
Old 06-04-2003, 12:06 PM
Thanks Clois
I can't wait for tomorrow night when I yank the motor and drop the pan. Hopefully, all teh lifter debris will be in hte pan.
Will remove one piston to see how the skirts and the cylinder bores look. Hopefully, no damge.
I will have the block hot tanked, magnafluxed, and install new rod/main bearings as well as new cam bearings. I bought a new oil pump as insurance.
Since I'm changing from a mechanical flt tappet cam to a hydraulic roller, I'm going to go with the manufacturer's recommended springs as insurance.
I will again check piston to valve clearance, and prime the engine with a drill motor PRIOR to starting it up.
Bill D
  #36 (permalink)
Old 06-04-2003, 01:13 PM
427sharpe's Avatar
Venom---I am a tad confused, you said earlier that 'Edelbrock said that their springs would work with my cam'...does this mean you put a set of Edelbrock springs on a Comp Cam? If so, this may be the source of your trouble, because edelbrock springs have a different bind height than Comp Cams (generally) and this may have meant that your springs were at absolute compression during the cam's travel, which would give you a bind and compress the lifters. I would almost guess that your pushrods are too long...I would also HIGHLY reccommend you hot tank the block, change the cam (probably destroyed) and ALL the bearings in the motor and then have the block thoroughly cleaned again. And don't forget to flush all the cooler lines and the cooler!
  #37 (permalink)
Old 06-04-2003, 01:15 PM
Yep, the cam is destroyed. Lobes look like they got beat with a ball peen hammer.
I only hope the pistons and cylinders are undamaged. I would hate to have to put new pistons in.
BD
  #38 (permalink)
Old 06-05-2003, 01:17 PM
Default Mr. Fixit & others...
You suggest replacing the oil cooler in this particular case due to the inability to flush the lines. I spun a bearing in my FE and had some debris in the pan, so this is probably stupid but do you suggest replacing my cooler as well. I know I probaly will hear debris is debris so replace it. Thank you!
Cracker
  #39 (permalink)
Old 06-05-2003, 01:29 PM
Mr.Fixit's Avatar
You guessed it. An oil cooler is like $200, how much money do you have in your FE where taking a $200 gamble doesn't leave you with an uneasy feeling? You cna flush the lines, but the cooler will hold onto the metal debris.
  #40 (permalink)
Old 06-05-2003, 01:33 PM
Default alot more thank $200 bucks!
Thanks and your right about the FE (bad FE, bad bad bad FE).
Cracker
