Old 07-28-2004, 05:19 PM
luke-44's Avatar
Default Do U Use Loctite on Headbolts?
In reassembling an Edelbrock head onto an FE motor, should you use Loctite on the head bolts? Yes/No? What about internals such as oil pump? Thanks,
Bruce
Enjoyment may be 9/10's anticipation, but that last 10% is oh so sweet....
Old 07-28-2004, 05:46 PM
Ibr8k4vetts's Avatar
No and no, use some oil and thats all. Hope this helps
Old 07-28-2004, 06:00 PM
jschiller's Avatar
Cobra Make, Engine: Past owner ERA 146, ERA 694 in progress, 428 CJ, toploader
You should Locktite the cam bolt to secure the fuel pump eccentric. Thats the only one. If you use studs to hold on the oil pan, you could Locktite those, I suppose.
Old 07-28-2004, 06:15 PM
ItBites's Avatar
I have used Indian Head Gasket Sealant on head bolts that go into water jackets. It does not set-up hard and prevents water leaks.
Do not use loctite.
E. Wood
ItBites
Old 07-28-2004, 06:33 PM
48 IDA's Avatar
Cobra Make, Engine: 1965 Contemporary 427 SC. built in 1982 before CCX serial #. has body #106. engine 351-C with 48 IDA'S 500 hp, T-56 6 speed, Halibrands k/os. Featured in KIT CAR, MOTOR SPORTS MONTHLY, AUTO X, AND SPORTS CAR. Original owner/builder
No, no, and no. Use engine oil only.
Don
Old 07-28-2004, 07:30 PM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Default NO
No, NO, no.
Use assembly lube like the stuff you get with the bolts.
Increment the torque wrench slowly at 10 pounds per set of bolts until you reach your desired setting.
If aluminum, make sure your put the washers on or you'll be sorry.
