Old 09-07-2004, 07:12 PM
elgecko's Avatar
Cobra Make, Engine: Scratch build......a little every day.
Question fe motor mount selection ???
HI
Can someone help me with a selection of a motor mount for this type of pedestal mount ??? I am using a 390 fe that has 3 bolts that holds the mount to the block and a single threaded stud that extends thru the "rubber".
The hole in the pedestal base is threaded. What is the procedure of mounting a motor mount to this pedestal ? or do I need a different mount?
Lots of questions and no nearby original Cobras to look at. I will TRY to load a pic to look at. If not.... there is one in my gallery.
Thanks
Dave
Old 09-08-2004, 05:42 AM
Clois Harlan's Avatar
Dave,
I am sure your mount will work but I used a U shaped mount about 4" ear to ear. Mine is a two piece design that I bought from NAPA. My frame mount is a bracket that incorporates a 1/2" tube that my u bracket straddles. I run a 7/16" bolt through from the ear to ear through the frame tube. For 5 years it has worked quite well.
Sorry I couldn't help with your particular motor mount. However, if I am not mistaken there were several applications that used your type of motor mount (390 Mustang-Pickups-heavy pass cars).
Clois
"Let's roll"
"Be part of Something Good
Old 09-08-2004, 06:05 AM
Cobra Make, Engine: EM Replica, 427 s/o, Vette suspension
Clois,
Would you happen to know the NAPA part number for the mount that you are using? I'm trying to install a 427 FE in a chassis that has frame mounts like yours and I can't identify the correct motor mount.
Thanks!
*** OF GREAT WORTH *** And JESUS asked again, “The Kingdom of GOD, how shall we think about it, and to what can it be compared? Is it not like a Dark blue 427 Cobra, which a man found parked on his street one day? He hurried off and sold all that he had; the ’57 Thunderbird, the ’63 Stingray, the XKE, and bought the dark blue 427 Cobra.” The disciples frowned and scraped their feet; JESUS grinned and popped the clutch. --- Harris Wolfe
Old 09-08-2004, 08:54 AM
Club Cobra Member
Original Shelby Owner
Cobra Make, Engine: Purchased CSX3225 in 1968 for $4,995. Original 428 car but changed to 427 MR about 20 years ago.
I found a 66 ford big block mount at the local parts store that looked right but did not work. I got several from several different local stores plus a set from Motorsports International. They all were close but did not work. I finally found a pair of original old stock units that worked. From what I understand there were some differences in the original mounts. I have included a picture of the mounts that didn't work. I will also send a picture of the mount that worked. I had changed the mounts earlier and bought a set directly from Ford so I didn't expect any problem and so I had tossed the old units before I tried the new ones.
Have fun, Ray
Old 09-08-2004, 09:02 AM
Club Cobra Member
Here is the one that worked. I don't know why there should be such a difference since I think both are supposed to be for the same application.
Have fun, Ray
Old 09-08-2004, 09:11 AM
Club Cobra Member
Here are the two mounts with the studs lined up. This shows the difference. Also notice that I had to grind off a corner of the mount to make it work on my side oiler block.
Have fun, Ray
Old 09-08-2004, 09:20 AM
I believe the mounts that work are out of a 61-62 Galaxie big block car. You can purchase them through Napa or even Kragens.
Good Luck, Tom
FE Specialties Your West coast FE source. We build FEs with todays technology, not circa 1970. We can supply you with any type of engine and drive train parts. From mild to wild. We engineer engines, not just throw parts at them. I currently am campaigning a 67 coupe that has C4AE-G iron heads, full interior, 3300 lbs. 10.51 @ 130.5mph. 665 HP(revised) with 11.6 to 1 comp. single 4 barrel.
Thanks Much. Tom
Old 09-08-2004, 09:48 AM
elgecko's Avatar
Thanks guys.
All the responses will keep me busy. NAPA seems to be a good place to start.
Dave
55 mph is unsafe at any speed. Huh?
Old 09-08-2004, 10:30 AM
jdog's Avatar
Cobra Make, Engine: Shelby CSX4795 (Sold)
Default Mine Too!
Thanks Tom,
We had better get a set of these for my car also.
Talk to you soon
jdog
"If you can't run with the BIG DOGS, stay under the porch!"
Old 09-08-2004, 10:58 AM
Dave, ccomt
Tom is correct because that is the year of the motor mounts that I ended up buying. Be prepared the boys at NAPA will need to look them up in their catalogue (these were not on their computer when I bought mine) and it took a while so don't go in on Saturday morning about 9:00 and expect to be out of there in 10 minutes. Jus kidding.
Good luck,
Clois
"Let's roll"
Old 09-08-2004, 12:18 PM
Anchor or Doan part # 2110 and #2141 will work just fine for you
Application is '60 thru '64 full size Ford
They bend 'em, we mend 'em.
