Old 02-10-2005, 06:47 PM
Dennis Mosley's Avatar
Cobra Make, Engine: Contemporary CCX33849 (currently 460)
Question RTV question
I know many of you use either Blue or Orange RTV on the front and back of your intake manifolds instead of the Cork. Is there a problem using the Black RTV? I'd rather not use orange or blue if I don't need to and plus I already have the black.
I've always used the cork before...and it's always leaked. Thought I'd go the RTV route with the new manifold.
Thanks in advance.
The future is no place, to place your better days....
Old 02-10-2005, 09:43 PM
Cobra Make, Engine: unique 427 302/300hp t/5
try www.caswellplating.com it will explain the different types .hope this helps
Old 02-10-2005, 10:43 PM
Mine was orange, tried to clean it up but it still showed. Black is a good idea, I'll look into that too.
Getting ready to drop my intake back on...
Old 02-11-2005, 04:12 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Used the black and the blue, both work.
Black was easier to deal with, as my engine is yellow.
I used Ultra copper on the headers and it still looks iritating.
Old 02-11-2005, 04:23 AM
Ron61's Avatar
Post
I have used both the Orange and Black and have not had a problem with either. Best stuff I have found is called The Right Stuff and is black. Comes in an aresol can and you just cut the plastic tip to put out a bead then let it set. Rick Parker told me about it and it has stopped a couple of seeps that I had from the transmission and another place.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 02-11-2005, 05:06 AM
where can you find "the right stuff"? Is it something you have to order or can you pick it up someplace like autozone or Napa?
Old 02-11-2005, 05:09 AM
Ron61's Avatar
Post
Dennis,
I got mine at NAPA.
Ron 61
Ronnie Widener
Old 02-11-2005, 07:35 AM
I stopped by NAPA on the way in to work today and picked up a can of "The Right Stuff".
Stuff ain't cheap so I'm glad I had someone to vouche for it.
Thanks guys!
Old 02-12-2005, 10:33 AM
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
Most RTV that I use black ,white and clear are not oil resistant and expand after prolonged contact with oil . The orange is higher temp and some what oil resistant. The blue is oil resistant. The blue takes longer to set up. The orange has set up so fast on me that I didn't get around an oilpan flange before it was getting grainy when I tried to smooth it out.You can form a RTV gasket by applying the RTV to one surface and after some setting up a coat of oil will keep it from sticking to the other surface like a valve cover or thermostat gasket that you may want to take appart again.
Mike H
