February 2026
Old 05-06-2005, 04:57 AM
Cobra Make, Engine: shell valley,63 427,alum. heads,everything roller
Question oil pressure spring and valve
Where can I find oil pressure by-pass spring and valve for 427 that goes in back of block,can't get get in touch with guys at FPP. thanks.
Old 05-06-2005, 05:50 AM
FFR428's Avatar
Cobra Make, Engine: HM-2027 / 427 SO
www.dscmotorsport.com Click on the engine block and part section. Oil relief valve kit $48. For TO and SO applications. Some guys make there own from an old oil pump plunger also. G.
Old 05-06-2005, 12:33 PM
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
Relief valve in rear of FE block? Did I miss something?I didn't see a spring or releif valve in my 427 FE Side oiler service block. The only releif valve I saw was the oilpump releif valve spring.The vented plug behind the timing chain gear to vent any trapped air in gallerys and squirt oil on chain
Mike H
Old 05-07-2005, 02:41 AM
Naumoff's Avatar
Cobra Make, Engine: Unique 427 S/C 427 FE S.O. 484 cu in
Mike it is the high pressure relief valve in the rear of the oil galley.
It blows off oil back into the pan when the oil pressure gets to high. I don't have a picture handy. I not sure but your service block should of had it too. There should bee a couple of allen plugs where they Machined the oil passeges from the rear to the front of the block. There's three around the cam plug and the two down the leftside. This is just from memory so you might want to check out some other resource or maybe someone can post a photo hear.
Tony
Rate This Thread:
