Old 07-23-2005, 05:08 PM
dlampe's Avatar
Default rubber motor mounts to soft, help?
My 427 really torques on the rubber mounts but I really don't want to go with solid mounts. Is there anything in between?
High Maintenance Racing Team
Run & Gun 2003 - 2013
Old 07-23-2005, 05:23 PM
Cobra Make, Engine: In Limbo for the time being
Dean ,
check out this site , although I did not see anything for BB if you call and speak with them maybe they can help you out.
http://www.suspension.com/mustang.htm
Old 07-23-2005, 05:36 PM
427sharpe's Avatar
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
Quickest way...drill 2 holes completelt thru the mount and backing plate a run 2 Grade 8 bolts thru the holes with washers under each end and a nylock. Tighten them to ALMOST contact the rubber and it will solve the torque problem while still letting the rubber isolate the vibrations.
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
Old 07-23-2005, 09:55 PM
joea's Avatar
Cobra Make, Engine: ERA #676, 428SCJ (2x4), TKOII
do this...
http://www.erareplicas.com/427man/en...tmod/index.htm
"There are 10 types of people out there....the ones that understand binary and the zeros that don't."
Old 07-24-2005, 08:55 AM
Cobra Make, Engine: SPF 2010; CSX581-->502 C.I.
Another option is a poly mount made by Craig Aylsworth. I used them in my SPF with a Shelby block, and there is little vibration, and no chance of header slap on the body. Very stout, and very clean installation. Much better than modifying a rubber mount.
Here's a photo, and Craig's e-mail. The cost for mine was $283 + shipping, but well worth it.
craigayl@comcast.net
Installation was a snap, and the alignment bolts made it easy to install, with no worries of misalinged bolts or damaged threads.
Miles
MJ
Old 07-24-2005, 11:27 AM
vettestr's Avatar
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
Use a torque strap or chain. Use 6 to 8 inchs or what ever length is needed . Run a 3/8 bolt into the front of the head on the side that raise through the link on the end and attach the other end to the frame, so there is limited slack. When normal movement is happening no change or vibration added. When it is tugging on or trying to tear the mount it should hit the limit of the chain and stop movement. Steel rope or cable also works great and you can get fancy ends and fastners to build it (located in same section of the store). Use at least 3/16 diameter, and its also available with plastic sleeve to reduce wiskers that cut you.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
