  #21 (permalink)
Old 08-09-2005, 03:42 AM
Burgs LM1 kit has 1 sensor. I have a friend that said he can make a box with an A-B switch to get reading off both sensors while driving. I will look at the data log later. TOO much going on when racing. I only worry about that oil pressure gauge and the reading on long sweeping turns. Back to Dean Rick Lake
  #22 (permalink)
Old 08-13-2005, 07:21 PM
SCOBRAC's Avatar
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
What Just One and Ex said...
I wonder if you have as much cam as you believe you do. I have a similar set up but run bigger valves and 1320 cfm. I make 535 at the crank.. I'm not knocking your hp. I'd say it's close to 475-495. at the crank... But at 13:1 you should be close to 550 or better.
Hotrod Magazine built a 390 that went 9.7:1 and got 450 hp at the crank. It was a roller cam motor that had 222 / 228 degrees of duration with .584/.604" of lift...
http://www.hotrod.com/webonly_january/
So I dunno.
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
  #23 (permalink)
Old 08-14-2005, 05:57 AM
dlampe's Avatar
I think the roller is worth 40 or 50 HP. I called Crane and they confirmed the part number and sent me a new cam card that matched what I already had. I can't look at the cam very easily but I guess I could measure the lift at the rocker and see if it is close. I don't have a dial indicator but my neighbor does. I is also possible that my compression is not that high, but I don't know how to check that with the heads on the car. It really does run well!
High Maintenance Racing Team
Run & Gun 2003 - 2013
Rate This Thread:
