Old 08-11-2005, 11:08 AM
priobe's Avatar
Default relocation oil filters
Hello all,
I would like to know if most of the people are using remote oil filter with cooler? I was told that there would be a pressure lost and it is not recommended.
I have a 427 SO.
Please need help with decission
Relocate or not to relocate?
Old 08-11-2005, 12:34 PM
Ron61's Avatar
Post
Priobe,
I have a 351 stroked out to 416 and I put a remote oil filter on it about 4 years ago. I never saw a bit of pressure loss. I did mine because it makes it a lot easier to change the oil filter without pouring the hot oil all over myself. Every one that I know around here has a remote oil filter on theirs.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 08-11-2005, 01:12 PM
priobe's Avatar
Thanks for the info. Ron.
Are you using -10 lines ?
Also are you using the sandwhich w/bypass kit relocation.
Here is the link http://www.cobraaccessories.com/cata...roducts_id=206
Old 08-15-2005, 10:13 PM
SCOBRAC's Avatar
I have 8' of -10 oil line, dual one quart filters and a cooler under the radiator. Total capacity about 3 quarts. I run a blueprinted Melling high volume pump and get 85 psi cold at speed, 75 hot. 50-55 cold at idle 40-45 hot.
A high pressure pump will get you 10-15 psi more across the board.
michael
Old 12-30-2005, 10:49 PM
Brent Mills's Avatar
Administrator
test 1232323323asdfasdf
