Old 04-18-2006, 01:40 PM
priobe's Avatar
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Default Need Help Rear Breather 427 & Webers
Hello,
I would like to know what you guys with the 427 are using for the rear ventilation. I currently using the "S" breather and would like to change it out for clearance on the rear firewall. Is it neccesary to use a catch can for oil if I use a plate with a tube, also if I use a breather will it blow oil everywhere?
Old 04-18-2006, 10:00 PM
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
I bought a plate to cover the rear opening where your breather is and installed my PVC valve there. You must have a breather somewhere; I use the oil filler tube breather that fits in the intake. You also must baffle the PCV valve; I use on of these Mr Gasket #5425:
I had to drill the hole in the plate larger (I think it had a 3/8 pipe thread in it originally), and if I remember correctly, used silicone to seal everything well.
Dan
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
Old 04-18-2006, 10:29 PM
Tongue Pirate's Avatar
Originally Posted by priobe
Hello,
The grommets on your screen filters. Are they they from the flat mesh screens that suppliers offer for webers or can they be sourced elsewhere?
Hyde D. Baker
Old 04-19-2006, 06:05 AM
priobe's Avatar
Are you referring to the black rubber grommets (yes these are the standard mesh screens)or the screens?
Also I have not found another source, if any anybody has please let us know.
Carnut427,
I have 2 breathers on the vavle covers, also did you install the pvc with a vaccum on the top of the pvc in the rear hole?
Old 04-19-2006, 07:11 AM
YUp, those are the ones. I have looked around with no luck yet. Maybe we have someone here in the grommet industry, or who has been, that can help us out with some info....
Hyde D. Baker
Old 04-19-2006, 11:45 AM
HSSS427's Avatar
Cobra Make, Engine: ERA #414 427 s/o w. Shelby Aluminum heads, Edelbrock Performer RPM Intake, Mighty Demon 750, Tremec TKO 600
Default Here's what's in mine
This is the wire basket that I think the originals used. I have this under my tall breather in the rear. You can buy these over the internet somewhere, as I did about a year ago. Just can't remember the source - maybe Finishline?
Old 04-19-2006, 08:29 PM
priobe, you can put a PCV valve in either of the valve covers or in the rear, it doesn't matter. I believe I've seen the wire baskets HSSS427 shows on ebay for somewhere around $50, which I think is ridiculous. Obviously if that's the only thing that works for you it's worth the money. From my experience, it depends on what you're doing with your car...roadracing puts more stress on the system, often needing a "puke tank" for excess oil to be collected in. Street driving shouldn't need anything more than a PCV valve. You can put a flat plate over the hole in the back of the intake and the PCV valve in a valve cover. The valve covers should also be baffled, and most are, with tin.
Strictly speaking, you don't even need a PCV valve; but the PCV valve collects the blowby and mixes it with the fuel charge. Oh, and yes, I ran a hose off the top of the PCV into the carb baseplate (straight vacuum, not ported).
Dan
Old 04-21-2006, 03:31 PM
I sell the breather baskets from Blue Tunder for something like 20 bucks.
Personally I just treat the FE like anything else and use a solid cover on the rear, and PCV/breathers in the valve covers. You really should have the PCV in one and some sort of breather in the other.
Barry R
Survival Motorsports
