January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 04-26-2006, 07:14 PM
JGC JGC is offline
Cobra Make, Engine: Superformance 695HP aluminum FE
Default Puke tank hose routing
Hello,
I just received my puke tank for my new Cobra build up and where should the hoses route to and from the tank?
Thanks,
Jack
Old 04-26-2006, 09:30 PM
luke-44's Avatar
my car doesn't have a puke tank -unlesss you mean an expansion tank - Suggest you check out a few of the pix on this site - get into the photo galleries - someone will show it.
Good luck...oh...and welcome to the madness..
Bruce
Enjoyment may be 9/10's anticipation, but that last 10% is oh so sweet....
Old 04-26-2006, 09:38 PM
CSX 4027's Avatar
Cobra Make, Engine: Sold 3047 & 3002 in 2012
Default tank
Pass side upper is a raod draft that snakes down the trans tunnel> Originally went to ground but, you should mount a catch can.
Pass side lower comes from/goes to oil pan.
Inboard side upper goes to rear manifold breather
Inboard side lower to top of tranny
All from memory but the inboards could be reversed. I forget around this time of night
Steve Sunshine
www.competitionlife.com
"Hurry Up And Live"
Old 04-27-2006, 06:28 AM
JGC JGC is offline
Thank you very much.
Jack
Old 04-27-2006, 09:46 AM
Cobra Make, Engine: Exact427
What is the actual position of the 3 screws holding this to the firewall???
I have seen the overflow with a rubber cap at times. I'll try to post a picture.
HOW DO I CHOP THIS DOWN TO SIZE, my puke tank is too big!! 79k vs 39k JPEG limit.. sorry.
Old 04-27-2006, 10:11 AM
computerworks's Avatar
Here are 2 pictures of the tank on Steve's car....
Old 04-27-2006, 12:30 PM
priobe's Avatar
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Is it possible to shorten the breather for the rear breather or add a filter to the rear, so that you do not have to use a puke tank?
