Old 08-23-2006, 09:42 PM
Default backfire
My car just started back fireing (on the right side only)between shifts.Just 1or2 pops ,but its never done this before.Anyone with any ideas where I should start to look
Thanx
Old 08-23-2006, 09:58 PM
Bryan Wilson's Avatar
Mike,
Check header pipes and flanges for cracks or air leaks that will do it.
cheers,
Bryan
VK3KDN
Old 08-24-2006, 04:08 AM
Tommy's Avatar
I agree. Leaky exhaust headers are a common cause of this problem.
Tommy
Previously owned EM Cobra
Old 08-24-2006, 04:28 AM
Clois Harlan's Avatar
Exhaust leak will do it every time!
Clois
"Let's roll"
"Be part of Something Good
Old 08-24-2006, 05:48 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Ultra copper on the header gaskets helps a lot.
Old 08-24-2006, 06:49 AM
Speedysnake's Avatar
Cobra Make, Engine: BDR - 351 / 385 hp
You can get a backfire from a loose plug wire, or any other cause of weak spark to one plug. Unburnt fuel ignites in the pipe on the side with the spark problem.
Speedy
Old 08-25-2006, 07:54 PM
Thanx everyone I will check it out
mike
Old 08-25-2006, 08:12 PM
STCinc's Avatar
Cobra Make, Engine: Superformance #1676
Be sure to check your distributor. I just had an MSD break a roll pin on the bushing above the timing gear. My car was also just backfiring on the right side.
Sean
Old 08-25-2006, 09:29 PM
SCOBRAC's Avatar
Thumbs up
we call that patina... enjoy
michael
Old 09-02-2006, 08:50 AM
Default back fire
found the problem ! loose bolts at header /sidepipe.
Thanx everyone !!
