Old 10-10-2006, 05:41 AM
Default Anyone have flow numbers for KCR Stage 1 Edelbrock heads?
Are they around 270/200?
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 10-10-2006, 08:30 AM
Brent, you might just send an email to KC or call him. I'm sure he'll be able to give you the numbers.
Old 10-10-2006, 02:01 PM
Default Stage 1
-----Original Message-----
Sent: Thursday, September 28, 2006 10:47 PM
To: Keith Craft, Inc.
Subject: [SPAM]Re: FW: Stage 1 Heads
The 427 style heads with the 2.19/1.73 valves in the stage one form will
flow about 280/220 and make up to 550HP depending on the camshaft and
cubic inches. This is with about a 10.5 to 1 compression. Thanks, Keith
Old 10-10-2006, 02:12 PM
Cobra Make, Engine: shellvalley 428 ford
Keith,
How about the stage 1's with the 2.09/1.66 CJ valves like Brent and I both have from you?
Thanks, Byron W.
Old 10-10-2006, 02:19 PM
Byron, I think that was an email from Keith to someone else.....I believe Keith's name on here is Keithc8
Old 10-10-2006, 02:40 PM
Yea, I think you are right. I saw Shelly and just answered. I will go back to sleep now.
Later,
Byron W.
Old 10-11-2006, 11:52 AM
Byron,
Sorry to confuse you. I had asked Keith for the flow numbers for my heads a few weeks ago. I recall seeing a before and after chart for stock Edelbrocks with 2.09 valves flowing 250/190. I am sure Keith's valve job gets that to around 270/200 and my bigger valves make it 280/220.
Old 10-11-2006, 12:29 PM
Snakepilot,
As you can tell at my age it does not take a lot sometimes. What heads and valves are you using? Also, will the 2.15 intake valves clear a 4.110 bore if used in the edelbrock heads? I have a pretty stout +060 390 going together for my Shell Valley car.
Thanks again,
Byron
Old 10-11-2006, 04:04 PM
I have Keith Craft Stage 1 427 Edelbrock heads. I have a 4.25 bore so I went with the 2.19/1.73 valves. If I had to run smaller valves, I might have opted for more porting. I don't know about your bore size, I went with KC's recommendation. He is tough to get a hold of on the phone, but will talk as long as you want once you have him on the line.
