02-27-2007, 11:40 AM
MD
Cobra Make, Engine: BDR #230 427 Big Block
427 side oiler
I know this is a very frquently asked question, but I bought this engine last year installed in my cobra. Can you tell me if this is in fact a side oiler, and if you know what this might have come out of or the year. I assume it's a '66 since it has that number stamped into the block. The block has screw in freeze plugs, and the main is crossed bolted. I can't seem to figure out how to down load the pictures on this site, it says the file is too large. Perhaps I could e-mail them and someone could help me out with the verdict. The numbers I could find are as follows:
In the valley: 427
26
On the rear of block: 66-427
On the front: 40
352
Any help would be much appreciated.
02-27-2007, 11:48 AM
OK
Here is the help you need. There is a software download 3/4 the way down that you can download to your desktop. After that you can right click and resize your picture then save it to your gallery and then you can come back to this post and attach it to your next post. Here you go:
Tips on Picture Uploads and Image Sizes
If that doesn't work email it to me at: clharlan@dcpmidstream.com and I will post it for you.
Clois
"Let's roll"
"Be part of Something Good
02-27-2007, 02:08 PM
MD
pictures
Check your e-mail I sent you the pictures
02-27-2007, 03:14 PM
Mo.
Take a look on the block exterior just underneath the oil filter, there should be a casting number there that will help identify it.
02-27-2007, 04:17 PM
KY
Easiest way to tell if it's a S/O is to look at the front of the engine. If you're facing it, look to the right of the timing cover. If there's a pipe plug there, then it's a S/O.
Also, it will have pipe plugs on the "humps" on the side of the block.
But the plug in the front is the easiest way....and you don't have to crawl underneath a car to check it.
02-28-2007, 04:58 PM
OK
Airvolts,
never received your pictures. try and send them to my office:
clharlan@dcpmidstream.com office email
tulsacobra@valornet.com home email
Clois
"Let's roll"
03-01-2007, 05:22 AM
OK
Here are some of your pictures of your 427. However, I believe it is not a side oiler but instead a Center Oiler (aka Top Oiler). I also believe it is possibly a 63 -65 production.
[IMG]
 [/IMG]
Brent join in here and tell me what you see.
Clois
"Let's roll"
03-01-2007, 05:27 AM
KY
First glance at the front says it's a C/O like you say. It looks like it's missing the pipe plug to the right of the front cover flange. It could be easily confirmed by looking at the side of the block and looking for the "humps" with the pipe plugs that indicate the oil passages along the side of the block.
OK
 [/IMG]Here is another picture:
http://[img]http://www.clubcobra.com/photopost/data/500/airvolts427d.jpg[/img
Since this is not working the way I want it to go to my gallery and take a look at the pictures.
Clois
"Let's roll"
03-01-2007, 05:36 AM
KY
Wow, from the side view it sure looks like a side oiler. I'm definitely not an expert by any means, but I don't believe the top/center oilers having the bulges on the side of the block. I'm trying to find a good pic of the front of a block that shows the oil passage I'm referring to.
03-01-2007, 05:46 AM
KY
Clois, here's a link to a picture that shows the pipe plug to the right of the timing cover.
I don't see that plug in the pictures above although the shadows may be hiding it. I'm pretty confused as his block does have the humps on the side...
http://www.clubcobra.com/photopost/s...what=allfields
03-01-2007, 07:12 AM
NC
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
airvolts: Get a copy of Steve Christ's How to Rebuild Your Big-Block Ford. It will asnwer most of your questions about any OEM FE Ford. In this case, pages 30 and 31 cover how to ID a center oiler or side oiler. With that said here are a couple more pix of a side oiler block.
Block has just been cleaned. Note threaded holes on the right side of the block between core plugs and cross-bolt holes. Note, also, the boss that runs front to back parallel with the main-bearing center line which are intersected by those holes. This is where the side oil gallery is drilled.
Here's a view of the back side of the block during assembly. Those two threaded oil-gallery holes to the left side (right side as pictured) of the crank flange confirms it's a side oiler. Center oilers have two above the cam plug. A side oiler has one as shown.
Hope the information "overload" helps.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
03-01-2007, 08:03 AM
MD
Clois did you receive the pictures of each side of the block? Also thank you for posting pictures for me. If anyone has a book that they could look up the numbers I provided I would greatly appreciate it.
Bryan
03-01-2007, 08:18 AM
MI
Cobra Make, Engine: Superformance Cobra SC, 514CID
This is not a great picture, but if you can make it out, it demonstrates what a side oiler looks like on the outside. This picture is of the left/drivers side from underneath the engine. There is an oil galley that runs down the side of the block just above the pan rail. Then at the 3 center main bearing webs a hole is drilled through the side oil galley to the mains. This hole is capped with a pipe plug
Some C/O's had the S/O casting but not the machining and some builders have been known to add the side plugs in these castings to give it the "appearance" of a S/O. The only way to know for sure is to remove one of the side plugs and verify that there is oil there
Craig
03-01-2007, 08:49 AM
OK
 [/IMG]A couple more pictures of Airvolts 427:
 [/IMG]
 [/IMG]
"Let's roll"
03-01-2007, 08:57 AM
OK
The numbers and letters you need are the ones found on the pass side front stamped near the #1 cylinder on the block. If your engine was sitting in the car they would be upside down.
C3AE
ABOF
Something like that
"Let's roll"
03-01-2007, 08:58 AM
MD
Thank you Clois you are a gentleman
Bryan
03-01-2007, 09:00 AM
OK
You are welcome, I went through the same thing a few years ago. By the way I have a 63 427 Center Oiler that puts out 535 hp at the flywheel and it is plenty stout.
Clois
"Let's roll"
03-01-2007, 09:15 AM
MD
Mine is being rebuilt/freshened up. Most of the parts that came with the car are fine just needed to be cleaned up. I have ross pistons,edlebrock performer heads and manifold, eagle rods,(2) holly carbs (not sure of the size),crane solid lifter cam, steel crank (which according to the guy building it weighs a ton). I'm not a engine guy so if messed up any of those terms don't shoot me. He is going to replace rings, rear main seal, bearings, and clean up everything. Then dyno and tune it in the car.
03-01-2007, 09:25 AM
KY
If some C/O's were cast with the humps, then the only good way of checking is to look for the pipe plug on the front of the block near the timing cover. In that case, I don't think Airvolt's block has this.
