Old 03-21-2007, 04:38 PM
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
Default 65-68 427 crankshaft question
i have a call into green sales looking for a oem 427 crank , they said there is 4 or 5 different cranks for these years?, does any one know what the 4 or 5 would be and where i could find part numbers or casting numbers?.
what crank would be best for a new build?.
Old 03-21-2007, 04:59 PM
How about a 428 1U crank, fits a 427 block nicely, easier to find and usually cheaper.
My hats off to you though for wanting the 'real deal', a steel 427 crank, very nice!
Old 03-21-2007, 05:30 PM
i wanted to find a original 427 crank if not i will go with the scat 3.98, it seems that every body is building 468 and 482 strokers with the 4,125 and the 4.250 stroke cranks. i was dissapointed to find out no body makes a replacement crank in the 3.78 stroke?.
Old 03-21-2007, 05:33 PM
I might have an original here - just showed up. At this moment it is condition unknown - thus price unknown. I would personnally cut down a 391 truck crank...
Old 03-21-2007, 06:37 PM
barry i had e mailed you i wanted to talk to you about a 427 for my ffr, when is a good time to call you?. i wanted some advise on a street motor using a genesis block, are the 468 and 482's to much motor for a cobra replica?.
would i be better off with the scat 3.98 crank 6.4 rods and 4.250 pistons
i want to use my mass flo fuel injection with a victor signle plane intake, i thought the bigger motors will need a lot of cyl head.
Old 03-22-2007, 04:51 AM
so where can i find info on crankshaft numbers?
Old 03-22-2007, 05:46 AM
flwolfman's Avatar
Cobra Make, Engine: None at moment
Barry, what has to be done to a 391 trunk crank other than the reducing the snout and cutting a new keyway? Thanks, Jim
Old 03-22-2007, 01:30 PM
I think you have to cut the flywheel flange as well, because it is thicker, and to do it right, I think you also need to trim the counter weights, because they are bigger on the 391 crank, and too heavy.
I run a cast "390" crank in mine, some 427's came with cast cranks, as mine was an original replacement short block with a cast crank from Ford. I've heard that drag racers preferred them over the steel ones, because they were lighter, i.e. faster, and still good for 700hp.
Old 03-22-2007, 07:56 AM
Cobra Make, Engine: ERA234 427s/o toploader
wrench 87,
Go to ebay and lookup midlifeclassics interchange books they have a neat one on all FE motors. I absolutley love mine.
Toby
.....oil dry magnate!
Old 03-22-2007, 10:06 AM
philminotti's Avatar
There's one on ebay right now.
http://cgi.ebay.com/Near-NOS-Ford-42...QQcmdZViewItem
Old 03-22-2007, 01:24 PM
Jac Mac's Avatar
Smile
Ford OE Part Numbers;
C4AZ-6303-H 427 4-8v 63/65 Iron
C5AZ-6303-C 427 4-8v 66/67 Steel
C8AZ-6303-B 427 4v SPL 68 Iron
C9AZ-6303-D 427 All All years Steel (Nascar - wide journal )
C7TE-6303-B 391(truck) All years Steel
Jac Mac
Old 03-22-2007, 01:29 PM
i dont trust it why would it have discoloration on some of the rod journals?
could it have been overheated? 1500.00 to buy now that is a little pricy.
i would have no problem buying a scat steel crank, but i wanted the 3.78 stroke. may think about a 391 truck crank but what are the machine costs to get it ready to bolt in?.
Old 03-22-2007, 02:48 PM
flwolfman's Avatar
Thanks Anthony. I have a 390 crank and a steel 391 crank. Just not sure which way I want to go for my 427. Jim
Old 03-22-2007, 03:47 PM
would i be better off buying a scat 3.98 crank over a vintage 390 crank?
what would be the pro's and cons?.
Old 04-07-2007, 06:29 PM
82ACAUTOCRAFT's Avatar
Cobra Make, Engine: AC Frua, FE Side Oiler
Using a 428 crank in a 427 block! Can it be balanced internally with mallory weight? Which is the best crank to use? 428, CJ, SCJ, Scat or Shelby?
Old 04-07-2007, 06:53 PM
lineslinger's Avatar
The use of a 428 crank in a 427 block is a common practice.
As to which crank is best is usually determined by what you are trying to accomplish with your engine, high torque, high RPM's, etc.
Which manufacturer is an often debated topic, I chose a Scat, quality product with a good reputation, I didn't go with Shelby because they pissed me off on the phone, but thats my issue.
At some point I may change out and use my steel 427 crank, but for now I am in pursuit of a torque monster, thus the 428.
Old 04-07-2007, 07:07 PM
In the past, I would have thought that using a stock stroke 3.78 crank would be giving up decent torque, but after I had my stock stroke 427 ( 4.250 bore - 429 ci) chassis dyno'd, it still was a torque monster. Peak RWTQ 488 @ 3850 rpm's (about 600 flywheel), and maintains above 450 ftlbs from 3500 - 5000 rpm's (about 560ftlbs at flywheel).
It just shows that you can build decent torque with a stock stroke.
Old 04-07-2007, 08:08 PM
I am in complete agreement with you Anthony, the 3.78 offers plenty of torque, but for my needs/desires, the longer stroke along with the higher compression offered by the 3.98 fit my plan to go faster sooner, quicker. I wanted the stump puller, especially from a standing start.
My build was from the bare block up, with the emphasis on a strong bottom end, and a new steel crank, not nodular iron, this was important to my plan.
Old 04-08-2007, 06:26 AM
Sorry it took me sooo long to find my way back to this thread. The gent that mentioned trimming the flywheel flange is correct. The counterweights are a something of a non-issue. Not real expensive work in the scheme of things - a few hundred will usually get a good core ready to run.
