Old 04-11-2007, 04:54 AM
Default Which cam are you running?
496fe Which cam are you running? I think he sells 4 customs, depends on the motor, bore and stroke. I am looking at the little one, for the motor in the car now with small 4.25 bore and 4.25 stroker. 10.0 compression. What is the specs on your motor. Rick L.
Old 04-11-2007, 07:52 AM
RedCSX1's Avatar
Rick, If you look at the specs of each cam you will find that they are very similar in lift, etc. Some one already mentioned Crane which makes a very nice roller cam that is somewhat smaller. Think it would be great for 454 or 468 stroke.
Morgan LeBlanc
Fresno CA
Old 04-11-2007, 08:47 AM
Rick,
You are correct: they make a few different grinds. Mine is the FB 3151R/3152B. .633" Int/.633" Exh valve lift. 252 Int./262 Exh. duration @.050". Here's the magic: 112 degree lobe separation angle.
Even your "little" 482 needs lots of air flow, so I recommend this same cam for you. My guess is that if you use 1) KC Stage II or comparable heads, 2) a good single-plane manifold and, 3) the above cam, you will have a pump-gas 590-610 Hp. streetable engine. Good job.
I got 607 Hp. with 9.4:1 compression with the above setup except I had the heads and manifold ported more.
Good luck
Brian
Old 04-11-2007, 10:07 AM
RedCSX1's Avatar
496fe and Rick,
I am running the very same cam in my 482 Pond/ported blue thunder dual plane intake and worked over edlebock heads (Keith just did a valve job on them). Compression 10:1
Morgan LeBlanc
Fresno CA
Old 04-11-2007, 11:56 AM
Red,
Sounds like you have a great combination. Did it dyno over the magic 600hp mark? They are a blast to drive aren't they. Especially because of the torque.
Brian
Old 04-11-2007, 02:16 PM
RedCSX1's Avatar
Brian,
Yes all the right parts. Now I am tinkering the carburetor. Thinking the 830 D.P. is too big. I think a good 750 DP might be a better carb and make it more street friendly and responsive. Strong recommendation from Tom of Tom's Motorsports to make the switch. I have gone to a nascar spun aluminum 14" air cleaner for daily use, this is the same style air cleaner that Tom uses on the Cobra Challenge racers. I will switch back to my S&H air cleaner for shows.
Morgan LeBlanc
Fresno CA
Old 04-11-2007, 02:34 PM
Our dyno runs showed that 750 CFM was plenty. I used the Demon instead of the Holley - use the Holley. I only had about 3 lbs. vacuum at 6,000 RPM, which shows that the 750 was plenty. As you know, for a street car, you always want the smallest carb you can.
BTW, I used a desktop computer program called Dyno2000. After putting in all the variables mutiple times, the calculated horsepower was within 5 Hp. of the actual. Some of those programs are amazing.
Old 04-11-2007, 02:50 PM
ST's Avatar
ST ST is offline
Cobra Make, Engine: Kirkham#182/Shelby 496c.i.
Agreed!
The 4150 HP 750cfm double pumper works well on my motor with just a couple of changes right out of the box
"You can NEVER teach a pig to sing! You'd just be wasting your time and annoying the pig!"
Old 04-11-2007, 02:55 PM
Cobra Make, Engine: KMP 498
Excaliber is right, "Real Men Use Soild Flat Tapet Cams"
That is what I am using as well. Rollers are definetly better: produce more power, create less heat, quiter, better gas milage, less smog producing and with todays venders and suppliers are becoming more dependable. Thank God for the new wave engine builders that are bringing this technology to our old beloved FE's. As advanced as these new cam systems are are becoming we may even be running with the Chevy's. Now you through in Kirkhams new block WOW! Anyway I am going solid, because real men do and the chicks dig it plus it is alot lighter and more original. You can't show me one CSX car out there that came with one!
Damn, the burden of being a real man!
Old 04-11-2007, 03:35 PM
Default What's a real man???
Big Boss What's a real man?? Excaliber lives on an island, and sits under palm trees half the day. His history of breaking motors and having Gessford fix the last one, sounds more like a problem between the brain and the right foot. Solids are more original, That's about it. With the right valve train and a .620-.650 lifter cam and seting up the correct hydro lifter lash, I can turn a motor to the 7,300 rpm. Your out of cam at this point and just wasting motor. You will get more power from a roller cam than a flat tappet. As far as chicks digging solids, only if it has the right vibration. Rick L P.s I think real men also use there given names BB.
Old 04-11-2007, 05:46 PM
Palm trees is it? More like banana trees in my backyard!
Well Gessford was certainly a major help with parts and advice when I built my motor, but I built it myself. A solid roller lifter let go and resulted in a major rebuild. Solid rollers, not a good idea for the street. Hyd rollers, work well on the street, but cost is considerably higher than flat tappet.
Old 04-12-2007, 07:36 AM
Rick Lake
As you are concerned my "Real" name is "big-boss" not a replica, not a kit name the real deal.
Another point: Limp dick ( hyd roller cams) are truly better. I once saw a documentry- I think it was "Girls Gone Wild" . They asked the question. Do Wild Girls like them Solid or Limpy? Overwelming the survey came back "Solid". You can not argue with that kind of data unless you are Al Gore of course-I am assuming you are not.
Everybody knows what a "Real Man" is - all us "Real Men" especially know the definition. Sorry, I will not be able to tutor you an that path- I will be too busy adjusting valves of course along with the heavy burden of having a chick magnet under the bonnet. When you reach "Real Mandom" you will understand. I will add that this type of dialog will help you. Good luck and yes --it is worth it!
  #33 (permalink)
Old 04-12-2007, 08:14 AM
Yet another good Club Cobra thread degenerated into size or state of dicks.
See you kids later.
  #34 (permalink)
Old 04-12-2007, 05:26 PM
Default Real Man
Big-Boss Tutor a man, You in the Military?? My Father was a Sergeant in the army, 2 purple hearts, shot twice, survivor of Pork Chop hill Korea. My Uncle 2 tours of Vietham and finished with 27 years in the Army. I have 3 fellow workers over in Iran-Iraq. I was talking about Lifters and you went off to some dumb place with girls wild and BS. REAL MEN. You have too much testicle matter between you ears. Hopes and dreams you need alot of both.
496fe sorry for this reply. Most people use there first names or sign off with there name. Special people are like BB.
  #35 (permalink)
Old 04-12-2007, 05:41 PM
FUNFER2's Avatar
I had CompCams grind me a solid flat tappet. 252/260, 600 lift @ .050 and 112 degree's lobe sep. I only adjust the lash twice per year. idles at 1,000 rpm, has a very loopy sound and is great on the street. I love the solids too. 563 HP
Kevin
  #36 (permalink)
Sheesh, I'm sorry I even brought up the 'real men' thing. It was just a tongue in cheek stupid remark meant to be funny!
  #37 (permalink)
Old 04-12-2007, 07:31 PM
FUNFER2's Avatar
hehe ! ya funny.
Kevin
  #38 (permalink)
Old 04-12-2007, 08:41 PM
RedCSX1's Avatar
Big-boss, Your wife told me she prefers BIG Hyd. Roller last time I saw her.
Morgan LeBlanc
Fresno CA
  #39 (permalink)
Old 04-12-2007, 10:25 PM
Morgan!!! I'm shocked!!!
  #40 (permalink)
Old 04-12-2007, 11:46 PM
decooney's Avatar
Solid lifter / flat tappet in my dinosaur FE, and I wouldn't have it any other way. Just gotta love it. KISS.
Duane
