04-11-2007, 04:54 AM
Which cam are you running?
496fe Which cam are you running? I think he sells 4 customs, depends on the motor, bore and stroke. I am looking at the little one, for the motor in the car now with small 4.25 bore and 4.25 stroker. 10.0 compression. What is the specs on your motor. Rick L.
04-11-2007, 07:52 AM
Rick, If you look at the specs of each cam you will find that they are very similar in lift, etc. Some one already mentioned Crane which makes a very nice roller cam that is somewhat smaller. Think it would be great for 454 or 468 stroke.
Morgan LeBlanc
Fresno CA
04-11-2007, 08:47 AM
Rick,
You are correct: they make a few different grinds. Mine is the FB 3151R/3152B. .633" Int/.633" Exh valve lift. 252 Int./262 Exh. duration @.050". Here's the magic: 112 degree lobe separation angle.
Even your "little" 482 needs lots of air flow, so I recommend this same cam for you. My guess is that if you use 1) KC Stage II or comparable heads, 2) a good single-plane manifold and, 3) the above cam, you will have a pump-gas 590-610 Hp. streetable engine. Good job.
I got 607 Hp. with 9.4:1 compression with the above setup except I had the heads and manifold ported more.
Good luck
Brian
04-11-2007, 10:07 AM
496fe and Rick,
I am running the very same cam in my 482 Pond/ported blue thunder dual plane intake and worked over edlebock heads (Keith just did a valve job on them). Compression 10:1
Morgan LeBlanc
Fresno CA
04-11-2007, 11:56 AM
Red,
Sounds like you have a great combination. Did it dyno over the magic 600hp mark? They are a blast to drive aren't they.  Especially because of the torque.
Brian
04-11-2007, 02:16 PM
Brian,
Yes all the right parts. Now I am tinkering the carburetor. Thinking the 830 D.P. is too big. I think a good 750 DP might be a better carb and make it more street friendly and responsive. Strong recommendation from Tom of Tom's Motorsports to make the switch. I have gone to a nascar spun aluminum 14" air cleaner for daily use, this is the same style air cleaner that Tom uses on the Cobra Challenge racers. I will switch back to my S&H air cleaner for shows.
Morgan LeBlanc
Fresno CA
04-11-2007, 02:34 PM
Our dyno runs showed that 750 CFM was plenty. I used the Demon instead of the Holley - use the Holley. I only had about 3 lbs. vacuum at 6,000 RPM, which shows that the 750 was plenty. As you know, for a street car, you always want the smallest carb you can.
BTW, I used a desktop computer program called Dyno2000. After putting in all the variables mutiple times, the calculated horsepower was within 5 Hp. of the actual. Some of those programs are amazing.
04-11-2007, 02:50 PM
NV
Cobra Make, Engine: Kirkham#182/Shelby 496c.i.
Agreed!
The 4150 HP 750cfm double pumper works well on my motor with just a couple of changes right out of the box
"You can NEVER teach a pig to sing! You'd just be wasting your time and annoying the pig!"
04-11-2007, 02:55 PM
Cobra Make, Engine: KMP 498
Excaliber is right, "Real Men Use Soild Flat Tapet Cams"
That is what I am using as well. Rollers are definetly better: produce more power, create less heat, quiter, better gas milage, less smog producing and with todays venders and suppliers are becoming more dependable. Thank God for the new wave engine builders that are bringing this technology to our old beloved FE's. As advanced as these new cam systems are are becoming we may even be running with the Chevy's. Now you through in Kirkhams new block WOW! Anyway I am going solid, because real men do and the chicks dig it plus it is alot lighter and more original. You can't show me one CSX car out there that came with one!
Damn, the burden of being a real man!
04-11-2007, 03:35 PM
What's a real man???
04-11-2007, 05:46 PM
 Palm trees is it? More like banana trees in my backyard!
Well Gessford was certainly a major help with parts and advice when I built my motor, but I built it myself. A solid roller lifter let go and resulted in a major rebuild. Solid rollers, not a good idea for the street. Hyd rollers, work well on the street, but cost is considerably higher than flat tappet.
04-12-2007, 07:36 AM
Rick Lake
As you are concerned my "Real" name is "big-boss" not a replica, not a kit name the real deal.
Another point: Limp dick ( hyd roller cams) are truly better. I once saw a documentry- I think it was "Girls Gone Wild" . They asked the question. Do Wild Girls like them Solid or Limpy? Overwelming the survey came back "Solid". You can not argue with that kind of data unless you are Al Gore of course-I am assuming you are not.
Everybody knows what a "Real Man" is - all us "Real Men" especially know the definition. Sorry, I will not be able to tutor you an that path- I will be too busy adjusting valves of course along with the heavy burden of having a chick magnet under the bonnet. When you reach "Real Mandom" you will understand. I will add that this type of dialog will help you. Good luck and yes --it is worth it!
04-12-2007, 08:14 AM
Yet another good Club Cobra thread degenerated into size or state of dicks.
See you kids later.
04-12-2007, 05:26 PM
Real Man
04-12-2007, 05:41 PM
Ne.
I had CompCams grind me a solid flat tappet. 252/260, 600 lift @ .050 and 112 degree's lobe sep. I only adjust the lash twice per year. idles at 1,000 rpm, has a very loopy sound and is great on the street. I love the solids too. 563 HP
Kevin
Sheesh, I'm sorry I even brought up the 'real men' thing. It was just a tongue in cheek stupid remark meant to be funny!
04-12-2007, 07:31 PM
Ne.
hehe ! ya funny.
Kevin
04-12-2007, 08:41 PM
Big-boss, Your wife told me she prefers BIG Hyd. Roller last time I saw her.
Morgan LeBlanc
Fresno CA
04-12-2007, 10:25 PM
 Morgan!!! I'm shocked!!!
04-12-2007, 11:46 PM
Solid lifter / flat tappet in my dinosaur FE, and I wouldn't have it any other way. Just gotta love it. KISS.
Duane
