05-03-2007, 08:07 AM
What Is The Correct Name for This Part?
It's the thing that screws on to the push rod coming out of the slave cylinder and that pushes against your clutch fork coming out of the bellhousing. Picture with helpful arrows below.
05-03-2007, 08:12 AM
Member of the north
Cobra Make, Engine: A Cobra
I call it the clutch activation rod. I made four for my car as I changed other things.
Just my $0.02
05-03-2007, 08:36 AM
How about adjustable clutch rod.
05-03-2007, 10:14 AM
Cobra Make, Engine: BDR 187 Prism Red w/Silver stripes; 427 stroker by Smeding Performance, Tremec TKO600 gearbox
It's either a thingamajig or a whatsit--I can't remember which.
'round Midnight
You'll feel me coming
A new vibration
From afar you'll see me
I'm a sensation!
-Pete Townshend, Tommy
05-03-2007, 10:29 AM
Uh-huh
I know it's got a name; and I know I've heard it before, I just can't remember it. At this point I'll even settle for a link to an item on a manufacturer's site that even looks close to it.
05-03-2007, 11:15 AM
I call it a clutch slave cylinder pushrod.
It looks like it's too tight on the fork so it might be a good idea to space the slave cylinder bracket forward on the block rather than changing the pushrod.
05-03-2007, 11:21 AM
That's ok, it's not mine -- I ripped that photo from page 35 of the ERA manual.
05-03-2007, 11:26 AM
I think it is like the little plastic things on the end of shoe laces, it does not have a name.
Or does someone know what those little plastic things are called?
05-03-2007, 11:28 AM
Hmm, maybe it's called a "clutch slave aglet."
05-03-2007, 01:11 PM
AL
Patrick -
I think you are referring to the collar that goes over the "slave cylinder rod." It looks like it can be screwed in or out to adjust the distance between the slave cylinder and the fork. According to this web site, it's called the "adjuster." See the blow up drawing about a third of the way down the page.
Click here.
Tommy
Previously owned EM Cobra
05-03-2007, 01:25 PM
Originally Posted by Tommy
Patrick -
Click here.
"Collar" is better than "aglet," which is better than "adjuster." Niblet is the worst of all....
05-03-2007, 02:09 PM
NC
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
My wife calls it a thingy and I call it a pushrod. There's a logical reason to use this term . . . it's a rod that's pushed on, adjustable or not.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
05-03-2007, 01:22 PM
Il
Cobra Make, Engine: LA Exotic
The shoe string "thing" is called a niblet
