November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 07-17-2007, 05:30 AM
Default Replace or have the head welded
Mike you are going to wash down all the bearing in that motor if coolant is getting into the oiling system. That motor will become junk. Coolant is NOT A LUBERCATE. If the head is Alum, send to a good machine shop and have it fixed and PRESSURE TESTED. A good welder should have no problem. After the head is repaired you may want to look into a coating company for sealing the coolant ports inside the head. Head repair with gaskets and parts under $700.00 if you do the work. Replacing an FE motor or rebuild price shock of about $5,000.00. Did you stay at a Holiday inn lately. Better to fix it correctly once that go cheap and get a major bill later. Rick Lake
Rate This Thread:
