Old 10-12-2007, 09:16 AM
joey_hv's Avatar
Cobra Make, Engine: Joey Manufacturing Inc.
Send a message via Yahoo to joey_hv
Originally Posted by CobraEd
A 390 FE with aftermarket aluminum heads, intake, and cam and only 400hp. You may have to pull a plug wire or two to do that!
ha! you may be right. thanks for the help guys. i'll look into the aluminum heads too. if i get the block drilled though will it be worth it in resale value later on?
"Me fodder was King Neptune, me mudder was a mermaid. I was born on the crest of a wave and rocked in the cradle of the deep. Me hair is like hemp, me arms are like spars. When I spits, I spits tar. I'm hard, I am, I is, I are. "
Old 10-12-2007, 09:25 AM
Originally Posted by joey_hv
.. if i get the block drilled though will it be worth it in resale value later on?
No, and it will only be seen when you have your car up on a lift. Not doing it will also save you from having to answer the question "Why did you cross-bolt your mains for 400 hp?"
Old 10-12-2007, 09:48 AM
CobraEd's Avatar
Just cut the heads off some old bolts and epoxy them onto the side of the block
________
________
Old 10-12-2007, 10:36 AM
joey_hv's Avatar
ha! ok, roger that, no drilling needed, gotcha!
Old 10-12-2007, 10:37 AM
joey_hv's Avatar
I prefer jb-weld on scams of that magnitude!
