Old 10-13-2007, 01:37 PM
Default 428 cobra jet vs. 460
i was wondering if a 428 cj or a 460 would be a better engine for a street rod. i am putting the motor in a FORD 1972 short bed single cab pickup. Also i was wondering if you hopped them up which one would have more horsepower and which one you could rebuilbd for less money, and which one would be less maintenance?
please give me any advice you have
thanks, 428 CJ man
Old 10-13-2007, 01:46 PM
The 460 would be cheaper, would make more power, and have comparable or less maintenence. Anybody can get good power from them, and you can stroke the snot out of them cheaply for big cubes.
That's why I build FEs.....
Survival Motorsports
"I can do that....."
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
Old 10-13-2007, 03:34 PM
convincor's Avatar
I'm doing a 68 f100 shorty.
Got the truck with a 460 and it's coming out.
It's a 76 which I'm assuming came out of a car as the C6 has the long tailshaft. The headers are butched in... Just don't like the setup.
I picked up a rebuilt 75 360 that's going in stock for now. It's a D4TE block which will eventually get a 4.25" stroke, aluminum heads etc...
There's just nothing like a FE.
02 Super Duty 7.3L
Old 10-13-2007, 04:00 PM
xlr8or's Avatar
It takes very little to get that 460 up to 600 HP and will cost half as much.
Old 10-13-2007, 06:24 PM
just how heavy is a dressed 460
Old 10-13-2007, 07:57 PM
Dwight's Avatar
Smile engine weight
here is a list I found online
Dwight
Ford 289/302 V8 460 lb
(late 5.0s are a bit lighter)
Ford BOSS 302 500
Ford 351 Cleveland 550 lb
(includes BOSS and Australian 302-C)
Ford 351 Windsor 510
Ford Y block V8 625 lb
(272-312 CID)
Ford FE big block 650 lb
(332-428 CID)
Ford FE big block 670 lb (1) ('59 352 CID)
Ford 429/460 V8 640 lb
Ford BOSS 429 680 lb
(iron block, aluminum heads)
http://www.team.net/sol/tech/engine.html
Old 10-14-2007, 01:16 PM
You really think an FE weighs more than a 460?
Old 10-14-2007, 02:01 PM
Dwight
Ford 289/302 V8 460 lb ...]
With aluminum heads, intake, flywheel, water pump, etc. my FE is within 50 lbs. of a stock 289. Honestly, when it comes to fitting a Cobra, you can't really compare a 460 with an FE.
Old 10-15-2007, 05:21 AM
Default Go Aluminium !!!
428 CJ man You might want to check out the FE forumn for info to start. A standard FE motor is 70 pounds lighter than a 460 iron motor. Why do you want a 700 pound anchor in the front of you car. It is easy to make 600 hp with either motor, but Aluminium motor FE will weight 470. A SVO 460 block is about 15 pounds heavier. FE is a smaller engine to fit in a car or truck in the bottom end. Save your money and GO ALUMINIUM. Sell the other motors to restorer builders. Rick L
Old 10-20-2007, 03:36 AM
coco_cobra's Avatar
Cobra Make, Engine: DRB 1996 302 windsor
i think the 460 can make more hp and cheaper can make 600
Old 10-20-2007, 03:52 AM
Dwight's Avatar
Smile He asked
truck ==== 460 rebuild for less money ======= 460
call the part store up and ask for the price on rings, gaskets, brearings for the 428 and 460.
Dwight
