February 2026
Old 10-18-2007, 10:13 AM
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
Default 70's 390 and oil mods?
i have a 70's 360-390 block that came with hydraulic lifters, what oil mods do i have to do to build my stroker motor. i have read so many different variations does any one have the newest and best information or advise on this subject?.
Old 10-18-2007, 10:19 AM
Here: http://www.gessford.com/projects/feoiling.htm
The most important thing to keep in mind is that if you do these mods and use a HV oil pump you absolutely, positively must use an after-market oil pan. If you don't, you'll kill your engine from oil starvation.
Old 10-18-2007, 01:39 PM
Keep it very simple.
Open and blend the feed hole from the oil pump into the block.
Restrict the oil to the rocker arms with a Holley jet or a piece of round stock - something in the range of .070-.090 is normally adequate. I still like to roll the corner of the main bearing feed to match the hole in the bearing - no need to remove much metal - just detail them over.
IMHO - Everything else is optional or in some cases of no value at all.
Survival Motorsports
"I can do that....."
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
