11-10-2007, 07:31 AM
Would need demensions of input shaft and shaft lenght
wrench 87 would need diameter of trans input shaft for where the pilot bearing is, lenght of the input shaft from trans case face to end of input shaft. Mike F. might have the right bearing like I said, Mine is for a GM trans input on an FE crank. Do you have the trans and you can check these measurements? This would get you in the right direction. You should also center the bellhousing to the crank shaft. Rick
