January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Like Tree1Likes
  #61 (permalink)
Old 11-14-2007, 12:00 PM
Default Jerry C
Jerry Clayton Jerry are you talking about cross drilling or gun drilling the cranks for a 180 degrees? If you find a couple of the old manuals for racing the FE motors they said not to fix the oiling hole to match the bearing holes. The off set holes acted as a limiter on the mains to oil each main and the 2 rod bearings. This is an old manual that talks about the oiling system. Roush machine cut open a FE motor and showed the galleys for the oiling system and how they got smaller the farther you get from the filter housing. Think the SO still is a better designed oiling system then center oiler. Rick L.
  #62 (permalink)
Old 11-14-2007, 12:26 PM
Jerry Clayton's Avatar
Rick
No . The ctanks were drilled with interconnecting passages from the front to the rear---you could put oil in number 1 and get it to come out number 8
Ford developed a crank for the 427 that had large passages drilled thru it, sealed the holes with plugs and snap rings--I.m sure you have seen some pics
Back then , it was stated in maybe an SAE paper or something similar that the centrifucacle force whould pump oil at 7000 rpm---
Up until then it was necessary to have enogh pressure to overcome c force of 1/2 the main dia at x rpm
Jerry
Rate This Thread:
