01-30-2008, 07:37 AM
FE Experts needed possible rebuild 427 SO
Hello all,
I wanted to get your take on a possible rebuild. Here are the parts which I currently have:
- Edlebrock Heads ( already ported and polished)
Valves SS. intake 2.190 / 1.730 Exhaust
- Dove Rockers
Will change- Solid Roller Cam shaft 245 intake / 250 exhaust @ 50
Valve Lift 660 665
- Block 427 1965 Side Oiler
- Crank $427 Steel Crank (C9AE-A-6303-A) Will need to get bearings
Rods NASCAR (C-7 OEA) 0.080 inch wider
- JE Pistons
Compression 9.5:1
- Oil Pump from Precision Oil Pump (blue printed)
- MSD Dist with 6AL
The motor is currently assembled and running pretty good. The reason for the possible rebuild is because the oil pressure seems too low at idle 10-15 psi. The oil pressure does jump up off of idle to about 45-60 and increases to 70 max. Another factor is that a leakdown test was performed resulting in a 26 % leakdown.
I am still in the build process, right before I send the body out to get painted. I really would not want torebuild the motor later when the body is already painted.
Since I am thinking of going back in I will change the cam because the motor idles very smooth. I understand that Webers have this effect on motors but this cam seems like it is for more HP in higher RPM range. Also, I am undecided on the crankshaft and rods. I have heard that it is hard to find those bearings but my engine builder say" its not a problem.
What to do ?
I am thinking that the clearances are too loose in the bottom end.
01-30-2008, 07:45 AM
Cobra Make, Engine: TBD, other is 67 Mustang GTA 390 Convertible w/air,
Engine Rebuild
I would change the Nascar rods. (heavy, obsolete, difficult to get bearings.)
What Edelbrock heads do you have?
Intake?, Carb?
Also, the cam may be a little to long in duration.
What is your goal with the engine?
01-30-2008, 07:47 AM
Rpm Fe 76 Cc
01-30-2008, 07:51 AM
Is that crank and rods worth anything????
01-30-2008, 08:22 AM
Originally Posted by priobe
The reason for the possible rebuild is because the oil pressure seems too low at idle 10-15 psi. The oil pressure does jump up off of idle to about 45-60 and increases to 70 max...
There is absolutely, postively, no doubt about it, nothing wrong with those oil pressure numbers for an FE.
01-30-2008, 08:24 AM
How about the leakdown test of 26 %
01-30-2008, 08:51 AM
That is a little bit high, even for a large CID engine. When you pressurize the cylinder and stick your ear by the oil filler cap hole can you hear
any sort of air noise? How about at your sidepipes? And at your stacks? With a loss of 26% you should hear the air leaking somewhere, and there's only so many places it can go.
01-30-2008, 08:52 AM
What are you looking for????
Priobe What are you looking for??? Race motor, street motor, something in the middle?? Lets start with about how much HP and torque are you wanting?? What are you going to do with the car? Show and shine, 1/4 drag race, Roadracing, Street driving, Autocross, High speed mile races?? The best thing a can tell you without more info is STROKER your motor to a 452 or better 482. Barry R sells a great stroker kit that is almost a straight drop in. A 10.5 compression with your heads. Sell the Nascar parts. The cam you have is too big for your motor and the low compression you are running. IMO you are not running enought oil pressure. I don't know what the clearances are on the mains and rods but there are only a couple of sizes available for nascar rods. You maybe able to use cleveland or windsor bearings with some machine work to the rods. IMO I would be running a 100 lb spring in the oil pump. Limiters to the rockers in the .070-.090" oriface range. If you have 25% leakdown you need to find out where all that air is going to. Piston rings not sealing, cylinder bores out of round, Valves not sealing in the heads to valve seats. You should find out this problem first before rebuilding the motor. Has this block been bored or is it a standard bore?? If you are running 48mm webers, the flow runs out at about 6,700 rpm with a 427 motor. It will be a little less with a stroker. If you put the right parts together for a certain rpm range you will get morepower and a better running motor. Match the parts. Exhaust, you can be loosing 20-50HP in this alone. Something to look into. Need answer for the first 4 questions before trying to give you info on a motor that would best work. Ps. Preoiler for your car. Accusump works great as a peroiler before starting the motor everytime. 80% of wear on a motors bearings are from startup. IMO I would also go to the ERSON full roller rocker setup. Have you any thought on an Aluminium block? Another 80 lbs off the front of the car would be nice. You could also run a hydro roller cam and lifters and have less maintainance. KCR sells some go cams for FI and webers. I have one for my 498 motor and 58mm TWMs. Talk to Keith about what he would recommend. May sure your machinist knows the different between FE motors with it's needs and wants and chevy motors.   The days of the .003" on rods and mains are gone due to the changes in oil.  IMO Rick L.
01-30-2008, 09:05 AM
... and are all of your cylinders uniformly running a 26% loss? Or just one, or some, of them?
01-30-2008, 03:19 PM
1. What are you looking for??? Race motor, street motor, something in the middle??
I am looking for something in the middle around 550 - 600 closer to 600 HP
2. What are you going to do with the car? Show and shine, 1/4 drag race, Roadracing, Street driving, Autocross, High speed mile races??
Show and shine street driving, once and awhile take to drag strip.
I really dont want to dump alot of money again into the motor if I dont have to. If I could make up the cost of with the NASCAR stuff then I will stroke it.
I am currently running a 100 # spring.
The leakdown test was done at a shop and I am not sure if it is all cylinders and where the leak is.
The motor is still fairly new with only 500 miles on it if that.
I am not happy with cam so I already mentioned that I want it out.
01-30-2008, 03:34 PM
If you are still building the car its probably a get bet that you do not have any miles on the motor. Right???..... It takes a little while for the rings to bed in and give you a good seal, and that oil pressure looks good to me, as long as it jumps as soon as you jazz the throttle.
01-30-2008, 05:35 PM
Chanmadd,
Thats what the guy at the shop said, except for the oil pressure. He also told me that he will replace the oil with straight 50 and cut open the filters to make a determination.
I am the one jumping the gun with the rebuild.
I am expect the worst and hoping for the best
01-30-2008, 06:21 PM
I will bet they have the wrong bottom end bearings in it  and I would run about 10.5 to 1 on compression depending on the cam.
Mike Z
01-30-2008, 06:26 PM
Ibr8k4vetts,
Do you have the part number of the bearing I need or brand or even place to buy them.
The this is a different shop working on the car now.
01-30-2008, 06:33 PM
Priobe, your oil pressure numbers are fine. I've seen dozens of well built FEs and those numbers are nothing to worry about. Did you know that from the factory the oil pressure idiot light didn't come on with FEs until they hit 4 lbs? So long as your pressure comes up when you blip the throttle, and you're getting upwards of 50 (and you're all they way to 70), your pressure is not an issue. You need to know more about the leak down tests though. That's a test you can do in your own garage and it may very well help you pin down some of your problems.
01-30-2008, 07:19 PM
patrickt,
Thanks for the info on the oil pressure. That makes me feel a whole lot better.
As for the leakdown test I will call him tomorrow to find out more specifics about this.
As for the cam, do you feel that it is good or should I change it?
01-30-2008, 08:24 PM
Ibr8k4vetts,
Sorry I don't, but I know there are Two sizes that are for the FE One is for race and is looser then the street bearing. You should be OK with what you have  but it made me nerves on mine  .
Mike Z
01-31-2008, 04:41 AM
patrickt,
I recall from previous posts that you were having problems with your Webers, a miss at 3500 or something like that, and that you felt your cam was not the best choice. Can you give us an overall description of just how your engine runs, idles, pulls at different rpms, etc.? You only have 500 miles on your engine -- that's brand-spanking-new. Nevertheless, a 26% loss on the leakdown is something that requires further investigation. You generally like to see the cylinders hold something in the 90's (when you pressurize them to 100psi); a big FE, maybe in the 80's. Going all the way down to the 70's though raises an eyebrow. I'd like to see the leakdown for all 8 cylinders. If six are high and two adjoining cylinders are low, that tells you something. Likewise if the kid tells you "Man I could hear air whistling out the passenger sidepipe when I did #2 and #4, but all the others did well." You get the idea.
01-31-2008, 06:19 AM
patrickt,
I ended up taking my car to a local shop that has had experience with Webers and 427 ford's.
After explaining the problem to him, as you mentioned,he asked me if my heart was set on these carbs. I responded by saying yes.
He was going to suggest to switch to dual 4 barrels and I told him let give the webers a try first.
I dropped the car off with a book of all the adjustment I have already tried and with the following new jets:
50 pump jets
135 mains
He was able to get the car running good in 1/2 a day.
He has done the following:
Change plugs
Compression Test
Leakdown Test
Set timing by rev motor to 3000 rpm and set timing to 36 degrees
change pump jets to 50
55 idles
100 holders
180 air
F7 e tube
135 mains
He has requested to put in F2 etubes to fine tune the mixture.
From what he says it is a completely different motor with alot more power. Popping has been eliminated!!!
He still has the car there he mentioned the leakdown numbers but told me lets see of the rings seat
He said he is not happy with the oil pressure but he will change the straight 30 to straight 50 and cut open the filters to make a determination of that.
He is not forcing a rebuild on me, he said lets wait and see some more results.
He is not happy with the cam either nor does he hate it.
I sttill have not yet seen or heard the car so I am just preparing for a rebuild if I need it.
01-31-2008, 06:38 AM
patrickt,
I ended up taking my car to a local shop that has had experience with Webers and 427 ford's ... From what he says it is a completely different motor with alot more power. Popping has been eliminated!!!
Well that doesn't sound too bad at all! My advice is to give it some time. You can move your oil up a viscosity level and then put a good 500-1000 miles on it before you do anything rash. Absent something unusual (like finding big gnarly chunks of metal in your filter), get some serious seat time in before you even think of pulling the cam.
