Old 02-14-2008, 06:40 AM
1966plus's Avatar
Question FE flywheel bolt pattern
Hi Guys,
another techie question for you.
Does anbody know the correct bolt pattern on an FE flywheel/crank? My flywheel from KEP has 2 holes at a slightly different radius from the other 4, whilst my crank (supplied on a built engine from Huddart Engines in the UK) has all 6 holes at the same distance from the centre. No matter how the flywheel is rotated only 4 holes will line up!
Which of these is correct for the FE? The flywheel will have to be modified whatever the answer, I would just like to know who has sent the correct spec part?
Craig
www.miragemk2.com
Old 02-14-2008, 07:05 AM
All holes on the same circle. One hole is offset though - the flywheel will only locate in one position. You will spend more time than you think finding the "right" spot...by spinning the wheel on the crank.
Survival Motorsports
"I can do that....."
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
Old 02-14-2008, 07:23 AM
1966plus's Avatar
Thanks for that, I knew that if there was an answer to be had then this would be the place to find it.
That helps out hugely
Thanks again
Craig
www.miragemk2.com
Old 02-14-2008, 07:25 AM
427 S/O's Avatar
Mark it with a punch, just in case it needs removed for whatever reason.
Perry
